Products: ACR9600,9630,9640
Note:
- uses 16bit integers to represent array subscripts for performance reasons. Arrays should not be declared in a way to use subscripts exceeding 16bit address limits, as this would lead to undefined behavior
The upper and lower bounds must always be specified as integers in the declaration. It is not possible to assign/change array length using a variable at run-time.
Expression are not allowed in the [index] assignment of any array. For example, x2[MyIndex+1]:=10; would result in an error. Instead, evaluate the expression prior to using in the index field: MyIndex:=MyIndex+1; x2[MyIndex]:=10;
Example1
The following declares an array of five integers and assigns initial values:
VAR
x1: ARRAY[0..4] of INT := [1,2,3,4,5];
END_VAR
Example2
TYPE
UserData : STRUCT
Score : REAL;
END_STRUCT;
END_TYPE
TopID : Array[1..10] of UDINT; (* array of 10 integers*)
tempData1 : UserData; (* structure of one int and 1 real *)
tempData2 : UserData; (* structure of one int and 1 real *)
TopTen : ARRAY[1..10] of UserData; (* array of structures of one int and 1 real *)
for index:=1 to 10 by 1 do
(*resets the top ten back*)
TopTen[index].id:=index;
TopTen[index].score:=100000.0;
end_for;
for index:=1 to 100 by 1 do
readparm.ParameterNumber:=39300+index;
ReadParm( Enable:=true | val:=value);
uID :=index;
if val >0.1 then
KeepChecking:=true;
IsTopTen:=False;
index2:=1;
while KeepChecking and Index2<11 do
if val<TopTen[index2].score then
keepchecking:=false;
IsTopTen:=true;
tempData1.score:=val;
tempData1.id:=uid;
end_if;
index2:=index2+1;
end_while;
if IsTopTen then
index2:=index2-1;
tempdata2:=TopTen[index2];
TopTen[index2]:=tempdata1;
index2:=index2+1;
for index3:=index2 to 10 by 1 do
tempdata1:=TopTen[index3];
TopTen[index3]:=tempdata2;
tempdata2:=tempdata1;
end_for;
end_if;
end_if;
END_for;
Example3
Y1: ARRAY[0..4] of real:= [0.0,0.0,1.0,1.0,0.0];
Y4: ARRAY[0..5] of real:= [0.0,-1.0,0.0,1.0,0.0,-1.0];
Y2 : ARRAY[0..8] of real:= [0.0,0.0,3.0,6.0,9.0,9.0,6.0,3.0,0.0];
Ys : ARRAY[0..16] of real;
index : INT:=0;
MAXINDEX : INT:=16;
HMIRadius : REAL;
1:(*Square;*)
maxindex:=4;
FOR Index:=0 to MaxIndex Do
Xs[Index]:=X1[index]*HMIRadius;
Ys[Index]:=Y1[index]*HMIRadius;
END_FOR;
2:(*Hex;*)
maxindex:=8;
Xs[Index]:=X2[index];
Ys[Index]:=Y2[index];
END_FOR;
Xs[Index]:=X4[index]*HMIRadius;
Ys[Index]:=Y4[index]*HMIRadius;
END_FOR;
END_CASE;
Example4
readP : ACR_ReadRealparameter;
readP.ParameterNumber:=int_TO_udint(index);
readP( Enable:=true);
parm[index]:=READP.VALUE;
end_for;
