Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Where Are The Digiplan ML Servo Motor Specifications?
Since the Digiplan Servo Systems were usually sold as a bundled packages consisting of Drive/Servo Motor, or Controller/Drive/Servo Motor, individual component specifications for motors may be difficult to find.  The Digiplan ML servo motor specifications may be found not only in older Compumotor catalogs, but also in the BL/BLH/BLHX user guides available on parkermotion.com/literature/User Guides/Obsolete Products/BL Series.
http://www.parkermotion.com/manuals/BL/BL.htm
Download any of the complete user guides that have a hardware reference chapter, and the ML motor specifications, including dimensions, are in that chapter.
JE 04/11/12
