Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What replaces Compumotor 23frame gearmotors?
The Compumotor integrated gearmotors are obsolete and no longer available. For replacements, the Stealth Gen II PX23 servo class gearbox is a very close replacement.
Performance comparison:
Dimensional comparison:
Torque comparison:
Custom PX23-L2 with larger output shaft diameter similar to the dual-stage Size 23 gearhead would be rated at 39Nm acceleration torque for 20:1, 25:1, 50:1, 70:1
*Custom PX23 available with lower backlash for high accuracy applications.
Note that the motors and gearheads are purchased as separate items:
1. SM231AE-NGSN.....Servo Motor
2. PX23-010-L2............Inline PX23 Stealth Gen II gearhead, 10:1 ratio low backlash
2. MU60-059................Mounting kit
The MU60-059 is the mounting kit for the SM23 motors and MU60-033 is the mounting kit for the BE23 motors.
The G05 was a 5.5:1 ratio, G22 22:1 ratio, G55 55:1 ratio. The Stealth has as standard 5:1, 20:1, 25:1 and 50:1 (exact ratios). The 5.5:1, 22:1 and 55:1 ratios could be done as custom.
Longer shafts to match the previous gearmotor and/or the Woodruff key are also available as custom.
The above is summarized based on catalog specifications. However, application requirements may be different; the PV23 value line gearhead could also be considered.
As reference for Compumotor Gearmotor catalog specs:
Compumotor Gearmotors
The integrated gearmotors have the pinion machined into the motor shaft and thus cannot be disassembled and the motor re-used with the new gearheads.
