Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Software - How do I write/read strings between Xpress (XPR) and ACR?
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
The following simple example shows how to use the .SS and .SSR tags in Xpress to write and read strings between the XPR and the ACR products.
ACR String Write-Read Sample
4/19/12 glh
