Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Training - Direct Drive Motors with Ethernet Powerlink Drives (I30) (Video)
ACR9600 EthernetPowerlink PAC controller connected with ethernet cable to Compax3 S063V2F10I30T11M00 servo drive controlling a Kollmorgen D061A-12-1210 Direct Drive Rotary servo motor with resolver feedback
Attached is a zip file with I30T11 Ethernet Powerlink files for the DDR D061A and DR D101B. These also contain the motor files that can be used on other Compax3 configurations.
KollmorgenDDR_with_Compax3_F10.zip
These use the standard resolver feedback option on the Kollmorgen DDR series servo motors. For files for the other size motors, email jhoagland@parker.com
9/16/14jh  files added
9/6/12jh
