Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base ACR Memory usage and commands
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
See also : User Variables
AcroBASIC Command
9000/9030/9040
Aries CE Controller
FLASH ERASE
Erases the user image from flash
Erases stored programs
FLASH LOAD
Loads the user image from flash.
Loads programs from flash
FLASH RES
Command returns the controller to factory settings. Performs the following actions:
  • clears all memory dimensioned for programs, variable, arrays, and data logging
  •  resets the communication stream dimensions
  •   erases all system parameters
  •  erases user images from flash memory
  •   resets the hardware configuration
  •   cycles power to the controller.
Erases motor configuration and user programs (ERASE + FLASH ERASE)
FLASH SAVE
Stores an image of the user programs and PLC programs in the flash.
If the image is detected in the flash on power-up, the card will load user programs and PLC†s from flash instead of relying on the battery backup memory. User Global Variables reside in battery backup memory and are not affected by the program transfer.
Saves all programs to flash
FLASH IMAGE
stores an image of the user programs and PLC programs, as well as the User Global Variables
If an image is detected in the flash on power-up, the controller loads the user programs, PLCs, and user variables from flash instead of relying on the battery backup memory.
ESAVE
stores system parameters into flash system parameter section to be retrieved on power-up or by issuing an ELOAD command
N/A
ERASE
erases all system parameter information from the flash system parameter. When you next cycle power, the controller uses the factory default settings or flash values.
NOTE: This command should be used with caution since it destroys setup information.
NOTE: returns IP address back to default.
NOTE: Program memory allocation is stored in battery-backup RAM, not in the EEPROM.
NOTE: FLASH commands (FLASH SAVE, FLASH ERASE, etc.) have no effect on the system parameters.
Erases motor configuration parameters and drive setup parameters and sets them to their defaults. Does not erase stored programs
Erased drive and axis parameters
Reboots controller
90x0PxUxMx
90x0PxUxBx
AR-xxCE
Save User Programs
FLASH SAVE or FLASH IMAGE
Programs retained in USER RAM with BBRAM
Save System Parameters
(Attachments, Masters)
ESAVE
ESAVE
Clear User Programs
FLASH ERASE
NEW or NEW ALL
FLASH ERASE
Save Axis Set-up  Parameters
(Gains, PPU, etc)
ESAVE
ESAVE
Retained in Non-Volatile USER RAM
Save Local Variables and Arrays
N/R*
Retained in USER RAM with BBRAM
Save User Global Double Variables
P0 - P4095
FLASH IMAGE
FLASH IMAGE
Save User Global Single Variables**
P39168 - P39423
N/R*
P39168-39231 retained  in Non-volatile User RAM
Save User Global Long Variables**
P38912 - P39167
N/R*
P38912-38975 retained  in Non-volatile User RAM
* N/R = Not retained after power cycle
**Requires OS revision 1.24 for ACR90x0, OS revision 1.13 for AR-CE.  These variables do not require dimensioning prior to use.
