Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I set my Dynaserv (G3) back to factory default?
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
Open the 'Terminal' window in the Dynaserv's DrvX3 Support Tool (shipped with the product):
1. Type @90:2003 and then click the 'Send' button.  (this reset the settings)
2. Type @96 and then click the 'Send' button.  (this resets the drive for the default settings to take affect)
Note - Cycling power will also allow the default settings to take affect.
glh 9/27/12
