Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Software - User Variables and Bits (Which are retained?)
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
IPA uses AcroBasic. Similar to AriesController.
See this posting: User Variables
