Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - EtherCAT Version - STO Wiring
P Series EtherCAT (PD-xxC) drive include Safe Torque Off functionality. The drives are shipped with a jumper to By-pass Connector for convenience. In order to access the pins on the CN6  STO connector, the following cables and connector are available.
APCS-STO03A 0.3 meter cable
APCS-STO10A 1.0 meter cable
APCS-STO30A 3.0 meter cable
APCS-STO00A No cable, Connector Only
APCS-STOxxA Breakout cable wiring
Wire Color
Pin Number
Name
Function
1
+12V
Bypass Wiring
2
-12V
Orange
3
STO1-
DC 24V GND
Orange w/Black
4
STO1+
Blocks the current (torque) applied to the motor when the signal is off.
Yellow
5
STO2-
DC 24V GND
Yellow w/black
6
STO2+
White
7
EDM+
Monitor signal output for checking state of safety function input signal.
White w/black
8
EDM-
The APCS-STO00A is a connector kit allowing customers to solder wiring for the STO circuit into the Pseries EtherCAT drive. Instructions ship with the kit:
APCS-STO00A Instructions
APCS-STO00A picture
10/3/16jh - added STO00A instructs & picture
