Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What replaces Compumotor 92frame gearmotors?
The Compumotor integrated gearmotors are obsolete and no longer available. For replacements, the Stealth Gen II PS90 servo class gearbox is a very close replacement.
Performance comparison:
Dimensional comparison:
Torque comparison:
Note that the motors and gearheads are purchased as separate items:
1. N0923HR-NGSN......Servo Motor
2. PS90-010-L2..............Inline PS90 Stealth Gen II gearhead, 10:1 ratio low backlash
2. MU90-001.................Mounting kit
The MU90-001 is the mounting kit to fit the N092 and J092 motors to the Stealth Gen II 90mm gearheads.
The G08 was a 8:1 ratio. The Stealth has as standard 7:1 and 10:1 (exact ratios). An 8:1 ratio has been done and is available as a custom.
The G12 was a 12:1 and G16 was a 16:1. The Stealth has as standard 3:1 and 4:1 ratios and these can be used for these same ratios as a custom.
Shorter shafts to match the previous gearmotor and/or the Woodruff key are also available as custom.
The above is summarized based on catalog specifications. However, application requirements may be different; the PV90 value line gearhead could also be considered.
As reference for Compumotor Gearmotor catalog specs:
Compumotor Gearmotors
The integrated gearmotors have the pinion machined into the motor shaft and thus cannot be disassembled and the motor re-used with the new gearheads.
