Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Misc - Dynaserv Replacements
In looking at the catalog specifications, below are recommended replacements for the obsolete Dynaserv systems.
The new P series have higher resolution Biss-C absolute encoders and can be used with the new P series or IPA series drive/controllers. As these are not a drop-in replacement, please review the new dimensions and specifications. A local Parker Automation Technology Center (ATC) distributor that has automation engineers on staff can review the application and review motor sizing requirements to determine if these are appropriate for your machine.
Dynaserv_PSeriesCrossOver.xlsx
DR Series Replacements
Series Feedback Peak Torque, N-m Cont, Torque Nm Max Speed, rpm Max Speed, rps Resolution, counts/rev Repeatability, arc/sec Accuracy, arc/sec Motor Weight, kg Rotor Inertia, kg-m2 x10-4 Diameter, mm Height, mm Thru Hole, mm Dynaserv Drive only Part No. Dynaserv Motor only Part No.
Dynaserv DRG3-1008B-115B Resolver 8 3 120 2 507,904 +/- 3 +/- 45 6 150 150 85 56 DRG3-1008B-115B-DO DRG3-1008B-115B-MO
Dynaserv DRG3-1008B-230B Resolver 8 3 120 2 507,904 +/- 3 +/- 45 6 150 150 85 56 DRG3-1008B-230B-DO DRG3-1008B-230B-MO
P Series PM-DDB03DN0H Encoder 9 3 500 8.3 1,048,576 +/- 1.3 +/- 30 6.3 5.7 135 78 20
P Series PM-DDC06DN0H Encoder 18 6 500 8.3 1,048,576 +/- 1.3 +/- 30 8.7 27 175 77 35
Dynaserv DRG3-1015B-115B Resolver 15 5 120 2 507,904 +/- 3 +/- 45 9 210 150 123 56
Dynaserv DRG3-1015B-230B Resolver 15 5 120 2 507,904 +/- 3 +/- 45 9 210 150 123 56
P Series PM-DDB09DN0H Encoder 27 9 500 8.3 1,048,576 +/- 1.3 +/- 30 9.2 11.5 135 124 20
P Series PM-DDC18DN0H Encoder 54 18 400 6.7 1,048,576 +/- 1.3 +/- 30 12.6 50 175 113 35
Dynaserv DRG3-1030B-115B Resolver 30 10 60 1 507,904 +/- 3 +/- 45 11 240 150 151 56 DRG3-1030B-115B-DO DRG3-1030B-115B-MO
Dynaserv DRG3-1030B-230B Resolver 30 10 120 2 507,904 +/- 3 +/- 45 11 240 150 151 56 DRG3-1030B-230B-DO DRG3-1030B-230B-MO
Dynaserv DRG3-1045B-115B Resolver 45 15 60 1 507,904 +/- 3 +/- 45 13 260 150 179 56 DRG3-1045B-115B-DO DRG3-1045B-115B-MO
Dynaserv DRG3-1045B-230B Resolver 45 15 120 2 507,904 +/- 3 +/- 45 13 260 150 179 56 DRG3-1045B-230B-DO DRG3-1045B-230B-MO
Dynaserv DRG3-1050A-115B Resolver 50 17 60 1 1024000 +/- 3 +/- 30 14.5 960 264 113 58 DRG3-1050A-115B-DO DRG3-1050A-115B-MO
Dynaserv DRG3-1050A-230B Resolver 50 17 60 1 1024000 +/- 3 +/- 30 14.5 960 264 113 58 DRG3-1050A-230B-DO DRG3-1050A-230B-MO
P Series PM-DDD22DN0H Encoder 66 22 400 6.7 1048576 +/- 1.3 +/- 30 19.6 68 230 100.5 60
Dynaserv DRG3-1060B-115B Resolver 60 20 60 1 507,904 +/- 3 +/- 45 16 330 150 207 56 DRG3-1060B-115B-DO DRG3-1060B-115B-MO
Dynaserv DRG3-1060B-230B Resolver 60 20 120 2 507,904 +/- 3 +/- 45 16 330 150 207 56 DRG3-1060B-230B-DO DRG3-1060B-230B-MO
Dynaserv DRG3-1070E-115B Resolver 70 23 90 1.5 614,400 +/- 3 +/- 45 22 850 205 183 76 DRG3-1070E-115B-DO DRG3-1070E-115B-MO
Dynaserv DRG3-1070E-230B Resolver 70 23 120 2 614,400 +/- 3 +/- 45 22 850 205 183 76 DRG3-1070E-230B-DO DRG3-1070E-230B-MO
P Series PM-DDD34DN0H Encoder 102 34 400 6.7 1,048,576 +/- 1.3 +/- 30 21.9 82 230 118.5 60
Dynaserv DRG3-1100A-115B Resolver 100 33 60 1 819,200 +/- 3 +/- 30 31 2000 252 185 150 DRG3-1100A-115B-DO DRG3-1100A-115B-MO
Dynaserv DRG3-1100A-230B Resolver 100 33 60 1 819,200 +/- 3 +/- 30 31 2000 252 185 150 DRG3-1100A-230B-DO DRG3-1100A-230B-MO
P Series PM-DDE40DN0H Encoder 120 40 300 5.0 1,048,576 +/- 1.3 +/- 30 28.2 311 290 95.4 75
Dynaserv DRG3-1100E-115B Resolver 70 23 60 1 614,400 +/- 3 +/- 45 26 1000 205 210 76 DRG3-1100E-115B-DO DRG3-1100E-115B-MO
Dynaserv DRG3-1100E-230B Resolver 70 23 90 1.5 614,400 +/- 3 +/- 45 26 1000 205 210 76 DRG3-1100E-230B-DO DRG3-1100E-230B-MO
Dynaserv DRG3-1130E-115B Resolver 130 43 30 0.5 614,400 +/- 3 +/- 45 32 1250 205 243 76 DRG3-1130E-115B-DO DRG3-1130E-115B-MO
Dynaserv DRG3-1130E-230B Resolver 130 43 60 1 614,400 +/- 3 +/- 45 32 1250 205 243 76 DRG3-1130E-230B-DO DRG3-1130E-230B-MO
P Series PM-DDE60DN0H Encoder 180 60 300 5.0 1,048,576 +/- 1.3 +/- 30 35 371 290 113.4 75
Dynaserv DRG3-1300A-115B Resolver 300 100 15 0.25 819,200 +/- 3 +/- 30 57 3400 264 304 170 DRG3-1300A-115B-DO DRG3-1300A-115B-MO
Dynaserv DRG3-1300A-230B Resolver 300 100 30 0.5 819,200 +/- 3 +/- 30 57 3400 264 304 170 DRG3-1300A-230B-DO DRG3-1300A-230B-MO
P Series PM-DDFA1DN0H Encoder 330 110 250 4.1 1,048,576 +/- 1.3 +/- 30 54 1410 360 131 115
Dynaserv DRG3-1400A-115B Resolver 400 133 15 0.25 819,200 +/- 3 +/- 30 68 4000 264 358 170
Dynaserv DRG3-1400A-230B Resolver 400 133 30 0.5 819,200 +/- 3 +/- 30 68 4000 264 358 170 DRG3-1400A-115B-DO DRG3-1400A-115B-MO
P Series PM-DDFA6GN0H Encoder 480 160 250 4.1 1,048,576 +/- 1.3 +/- 30 70.3 1763 360 167 115 DRG3-1400A-230B-DO DRG3-1400A-230B-MO
Dynaserv DRG3-5015C-115B Resolver 14 5 360 6 212,992 +/- 5 +/- 150 7 0.08 107 167 26 DRG3-5015C-115B-DO DRG3-5015C-115B-MO
Dynaserv DRG3-5015C-230B Resolver 14 5 360 6 212,992 +/- 5 +/- 150 7 0.08 107 167 26 DRG3-5015C-230B-DO DRG3-5015C-230B-MO
P Series PM-DDB06DN0H Encoder 18 6 500 8.3 1,048,576 +/- 1.3 +/- 30 7.2 8.7 135 100 20
Dynaserv DRG3-5030B-115B Resolver 30 10 240 4 278,528 +/- 5 +/- 90 7 80 150 184 56 DRG3-5030B-115B-DO DRG3-5030B-115B-MO
Dynaserv DRG3-5030B-230B Resolver 30 10 240 4 278,528 +/- 5 +/- 90 7 80 150 184 56 DRG3-5030B-230B-DO DRG3-5030B-230B-MO
Dynaserv DRG3-5070B-115B Resolver 70 23 240 4 278,528 +/- 5 +/- 90 17.5 360 150 240 56 DRG3-5070B-115B-DO DRG3-5070B-115B-MO
Dynaserv DRG3-5070B-230B Resolver 70 23 240 4 278,528 +/- 5 +/- 90 17.5 360 150 240 56 DRG3-5070B-230B-DO DRG3-5070B-230B-MO
DM Series Replacements
Dynaserv DMG3-1004B-115B Encoder 4 1 150 2.5 655,360 +/- 3 +/- 20 3 55 160 45 25 DMG3-1004B-115B-DO DMG3-1004B-115B-MO
Dynaserv DMG3-1004B-230B Encoder 4 1 150 2.5 655,360 +/- 3 +/- 20 3 55 160 45 25 DMG3-1004B-230B-DO DMG3-1004B-230B-MO
                      0
Dynaserv DMG3-1004C-115B Encoder 4 1 150 2.5 655,360 +/- 3 +/- 60 3 25 140 77 25 DMG3-1004C-115B-DO DMG3-1004C-115B-MO
Dynaserv DMG3-1004C-230B Encoder 4 1 150 2.5 655,360 +/- 3 +/- 60 3 25 140 77 25 DMG3-1004C-230B-DO DMG3-1004C-230B-MO
Dynaserv DMG3-1015B-115B Encoder 15 5 120 2 655,360 +/- 1 +/- 15 5.5 120 160 92 25 DMG3-1015B-115B-DO DMG3-1015B-115B-MO
Dynaserv DMG3-1015B-230B Encoder 15 5 120 2 655,360 +/- 1 +/- 15 5.5 120 160 92 25 DMG3-1015B-230B-DO DMG3-1015B-230B-MO
P Series PM-DDC12DN0H Encoder 36 12 500 8.3 1,048,576 +/- 1.3 +/- 30 10.6 39 175 95 35
Dynaserv DMG3-1030B-115B Encoder 30 10 120 2 655,360 +/- 1 +/- 15 7.5 150 160 118 25 DMG3-1030B-115B-DO DMG3-1030B-115B-MO
Dynaserv DMG3-1030B-230B Encoder 30 10 120 2 655,360 +/- 1 +/- 15 7.5 150 160 118 25 DMG3-1030B-230B-DO DMG3-1030B-230B-MO
Dynaserv DMG3-1045B-115B Encoder 45 15 60 1 655,360 +/- 1 +/- 15 9.5 190 160 143 25 DMG3-1045B-115B-DO DMG3-1045B-115B-MO
Dynaserv DMG3-1045B-230B Encoder 45 15 120 2 655,360 +/- 1 +/- 15 9.5 190 160 143 25 DMG3-1045B-230B-DO DMG3-1045B-230B-MO
Dynaserv DMG3-1050A-115B Encoder 50 17 60 1 1,024,000 +/- 1 +/- 15 14.5 960 264 113 58 DMG3-1050A-115B-DO DMG3-1050A-115B-MO
Dynaserv DMG3-1050A-230B Encoder 50 17 60 1 1,024,000 +/- 1 +/- 15 14.5 960 264 113 58 DMG3-1050A-230B-DO DMG3-1050A-230B-MO
P Series PM-DDD22DN0H Encoder 66 22 400 6.7 1,048,576 +/- 1.3 +/- 30 19.6 68 230 100.5 60
Dynaserv DMG3-1100A-115B Encoder 100 33 60 1 1,024,000 +/- 1 +/- 15 19 1190 264 138 58 DMG3-1100A-115B-DO DMG3-1100A-115B-MO
Dynaserv DMG3-1100A-230B Encoder 100 33 60 1 1,024,000 +/- 1 +/- 15 19 1190 264 138 58 DMG3-1100A-230B-DO DMG3-1100A-230B-MO
Dynaserv DMG3-1200A-115B Encoder 200 67 30 0.5 1,024,000 +/- 1 +/- 15 29 1670 264 188 58 DMG3-1200A-115B-DO DMG3-1200A-115B-MO
Dynaserv DMG3-1200A-230B Encoder 200 67 60 1 1,024,000 +/- 1 +/- 15 29 1670 264 188 58 DMG3-1200A-230B-DO DMG3-1200A-230B-MO
3/4/16jh
