Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base ACR-View: Mapping a parameter to an oscilloscope channel
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
You can map a parameter value to an oscilloscope channel that is not in the drop down menu list.
If you want to display a parameter on an oscilloscope channel that is not on the drop-down list, then you can manually map this parameter
You can't map a single bit to an Oscilloscope channel, but you can the parameter word, which makes up the bits.
Below is a screen shot that shows how the channels are set default.   SAMP0 SRC is for channel 1, SAMP1 SRC is for channel 2, and so on.  If I wanted to change channel 1 to be P4200, then I'd add to my code SAMP0 SRC P4200.
8/3/2016 nc
