Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base AcroBasic Program Priority and Timing
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
Products: ACR9000, 9030,9040,9600,9630,9640, Aries CE, IPA
16 AcroBasic programs are available for use in ACR controllers.  In the ACR9xxx's and IPA, Programs 0-7 are high priority and 8-15 are low priority. In the AriesCE Program 0 is high priority, 1-15 are low priority.
Controller Type
High Priority Programs
Low Priority
Programs
IPA
  0 - 7
  8 - 15
ACR9xxx(all variants)
  0 - 7
  8 - 15
Aries Controller
  0
  1 - 15
High priority programs each have a dedicated time slice, where the low priority programs share a time slice. Communications also have a dedicated high priority task. Each time slice is 1ms, within that time the programs will execute anywhere from 1-10 lines of code before switching to the next program in the queue.
An example of the operation order where 0-9 are all being used would proceed as follows:
0,1,2,3,4,5,6,7,COM,8
0,1,2,3,4,5,6,7,COM,9
Notes:
  • Programs will only utilize their time slices when they are actually running.
  • The program priorities are fixed in the controller, there is no provision for adjusting the priorities for the user.
  • DWL statements in low priority programs will cause the entire low priority slice to DWL
  • INH statements in low priority programs will inhibit the entire low priority slice
  • PROG15 is used by the ACR-View to store the configuration. Users should avoid using this program for other purposes.
edit 6-jan-2016  jw...add ipa
