Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Misc - What are the general requirements for supported SSI feedbacks?
Notes on the SSI sensor
  • With Multiturn: Number of sensor rotations with absolute reference
  • Word length: Gives the telegram length of the sensor.
  • Baud rate/step: Max. transmission rate of the path measurement system.
  • Gray code: Sensor gray code coded yes/no (if no binary coded).
Note:
The absolute position is not evaluated!
It is available in the objects 680.24 (load position) and 680.25 (master position) (C3T30, C3T40).
General requirements for supported SSI feedbacks
  • Baud rate: 350k ... 5MBaud
  • Word length: 8 ... 32 Bit
  • Binary or gray code (start value = 0)
  • Initialization time after PowerOn: < 1.1s
  • Signal layout:
    signal layout
The most significant bit must be transmitted the first!
Caution!Feedback systems, transmitting data containing error or status bits are not supported!
  • Examples of supported SSI feedback systems:
    • IVO / GA241 SSI;
    • Thalheim / ATD 6S A 4 Y1;
    • Hübner Berlin / AMG75;
    • Stegmann / ATM60 & ATM90;
    • Inducoder / SingleTurn: EAS57 & Multiturn: EAMS57
