Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Software - Xpress Recipe Naming
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
When naming your Interact Xpress Recipe within the development environment, please keep in mind the following rules:
1. Recipe names MUST begin with a letter, ie, Recipe001.
2. Recipe names CANNOT begin with or contain any spaces.
3. Recipe names CANNOT begin with a number or other character.
In releases prior to Xpress Manager 2.1.4, using the Save As button in a recipe during Run Mode would allow illegal entry of spaces or first character being numeric (or other non alpha character), but would not correctly save the information.  Later revisions of Xpress Manager do not allow for this illegal entry.
If you are using an early release, please keep in mind the rules above to minimize errors when saving recipes.
kj 8/24/12
