Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Training- C3ServoManager - How to Tune Linear Servo with the Compax3 (Video)
This video shows with the Compax3's C3 ServoManager software, how to tune a linear servo motor. In the Optimization screen, the Auto Inertia detection allows easy tuning for a linear servo motor.
CLICK HERE FOR VIDEO ON YOUTUBE.COM
10/1/12jh
