Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Upgrading A/AX Systems
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
If you have an existing A/AX system (which includes an A-Drive or an AX-Indexer/Drive and an A-Motor)...
The A-Drive can be replaced by Zeta Drive. It is a smaller footprint and will fit in the same cabinet space and has the same 25pin D-sub pinout on the front of the drive and also uses the same 120vac plug on the front of the drive making it a very easy upgrade.
The AX-Indexer/Drive can be replaced by an ZETA6000 Indexer/Drive. Note that the ZETA6000 uses a different programming language. However the 6000 series command reference guide gives a cross-over list from the X language commands to the newer and expanded 6000 series language.
However, an A-Motor cannot be replaced by an Zeta-Motor due to the high inductance specs of the A-Motor. An Zeta-Motor would be burned up by the A-Drive.
A-Motors are no longer available for purchase. However, the Zeta-Motors have similar dimensions as the A-series motors. ie A57-51-MO (-MO is motor only) would be replaced by the Zeta57-51-MO.
For full specifications on the A series motors, see the A/AX series user guide. These user guides provide speed-torque curves for the motors and dimension drawings. The Zeta series motors are shown on our website and are the same as the S series or ES series motors.
