Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Software - T30/T40 - Useful IEC Function Examples (Read Analog Inputs)
The following is a function designed for importing into the Codesys software when developing Compax3 (T30 or T40) IEC programs.
To bring this function into the Codesys environment, first download the file, then open your project in Codesys, and then under the Project menu, select the 'Import' utility and point to where you have the particular .exp file saved on your computer.
You can then add the particular function to your overall program as you would any other function or function block.  The imported function will be listed under either 'User Defined Functions' or 'User Defined Function Blocks'.
Read Analog Input Values Function Block
Note - This function continually provides the value of the two on-board analog inputs, X11 connector, in a REAL format.
Inputs:     none
Outputs:    Analog0 (REAL)
                 Analog1 (REAL)
glh 10/18/12
