Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PC Requirements for Parker Automation Manager (PAM)
      • PAM IDE-
        • Simulating a project in PAM
        • User Management in PAM
Min Requirements
Win7 32 bit - 4GB ram
.Net 4.51
Recommended Requirements
Win7 or Win10 - 4GB ram
.Net 4.51
glh  6/2017
