Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Command Syntax for Variable Substitution
        • Axis Flag update rate
        • Encoder Velocity
        • Evaluation Underflow error
        • How to receive ASCII data
        • INTCAP
        • Reboot in startup program
        • Use of AXIS format
        • User Variables
        • Using Encoder 8 or 9 as SRC
        • What is the axis velocity
      • 9000 (Legacy)+
For commands using variables instead of numeric values, the variable needs to be within parentheses.
Below is a simple program showing correct syntax.
PROGRAM
DIM SV10
SV2=100
SV3=6
ACC (SV2)
VEL (SV3)
DEC (SV2)
STP (SV2)
Y/100
? SV2
? SV3
INH 516
ENDP
Substitution Substitute Command Syntax parenthesis parentheses
