Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Where does ACR-View install the ComACRserver?
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
Beginning with ACR-View 6.3, the ComACRServer.exe is installed in a new directory:
C:\Program Files\Common Files\Parker Hannifin\ComACRServer
Previous versions of ACR-View6 would place it here:
C:\Program Files\Parker\ACR-View 6
