Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Trilogy Motors with Non-Parker Servo Drives
      • High Pot Option
      • Inspection Report
      • ML18 Track Weights
      • Omega 44004 Thermistor Info
      • Phasing Diagram
      • Renishaw Optical Encoders
      • Trilogy Electrical Pitches
      • Trilogy Extension Cables
    • MX80+
    • mSR+
    • LXR+
    • mPR+
    • XE+
    • XR+
    • ZP Wedge+
Allen Bradley Ultra 3000
Allen Bradley Ultra AB3000 to Trilogy Linear Servos
Copley 5211 and 7xx8AC
Copley 5211 and 7xx8AC to Trilogy Linear Servos
Emerson E series
Emerson E series to Trilogy Linear Servos
Pacific Scientific
PacSci PC830 to Trilogy Linear Servos
MTS Automation MAX Plus FLX
MAX Plus FLX Wiring Diagram to Trilogy Linear Servos
This information provided as legacy only, previously on Trilogy's website and not supported by Parker. For all new applications, we recommend Parker drives. See product pages for detailed application notes for ACR9000, Aries, Compax3 and Gemini.
