Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Inspection Report
      • High Pot Option
      • Inspection Report
      • ML18 Track Weights
      • Omega 44004 Thermistor Info
      • Phasing Diagram
      • Renishaw Optical Encoders
      • Trilogy Electrical Pitches
      • Trilogy Extension Cables
    • MX80+
    • mSR+
    • LXR+
    • mPR+
    • XE+
    • XR+
    • ZP Wedge+
Inspection Report
All IForce motor coils ship with an inspection report. Each report has the coil part number and serial number.
This quality report shows the coil's phase-to-phase resistance. The coil's nominal resistance is given as reference. It also shows ground wire resistance and the thermistor resistance.
It also shows the in process high pot test results.
12/7/2012jhoagland
