Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Kit Motors - Frameless Kit Motors (Inspection Report)
Frameless Kit Motors ship with an inspection report.
The report has the distributor's Sales Order number, motor part number and serial number.
The phase-to-phase resistance shown, back EMF, alignment of the back EMF to the motor phases and the inductance.
12/7/2012jh
