Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Troubleshooting - Codesys Error 5827 #1027 Unknown Command
When compiling if receiving Error 5827: #1027: Unknown Command, the command being used is a newer version than the compiler version being used.
Unless using older Compax3s, always use >=V03.04.00 (C3 2007R07) to give full functionality.  Using All Versions will compile for older firmware and some commands and functions may not be available.
2/1/2013jh
