Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Software - T30/T40 - Necessary Codesys components for T30/T40 and C3ServoManager
Why does the ENI Server start when Windows starts? How can I turn it off?
This cannot be disabled but is not currently used. This can be uninstalled.
However, you cannot uninstall only the ENI component. Unsinstall all of CoDeSys and then re-install.
Below shows during the Codesys installation the only necessary components for C3 ServoManager operation with the T30 and T40 servo drive cotnrollers:
3S Licensing Manager, CoDeSys SoftMotion, CoDeSys HMI, OPC Server, ENI Server, SP RTE, SP PLCWinNT and WebServ are not currently implemented and not necessary to install.
2/1/2013jh
