Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Software - How to get status values from an C3 EPL Drive (I30)
Updated 04-Feb-2013
Products: Compax3 EPL, SxxVxI30T11 ACR9030,ACR9040, ACR9630, ACR9640
By default a Compax3 EPL drive will report the following parameter back to the ACR controller every EPL cycle
Value Where to find Starting Parameter
Position EPL Parameters/EPLD Position Parameters/EPLD Position P38144
Velocity EPL Parameters/EPLD Position Parameters/EPLD Velocity P38145
Secondary Position EPL Parameters/EPLD Position Parameters/EPLE Position P38146
 Error Code  EPL Parameters/EPL Control and Status/Compax3 Drive Error Code  P37643
Inputs EPL Flags/EPLD Digital Inputs BIT3328
Following Error Axis Parameter/Position Parameters/Following Error P12291
Torque Axis Parameter/Monitor Parameters/Final Output Signal P12319
For explanation of Torque Values from Compax3 EPL, read here
For more information about the Error Code, read here
Additional information can be requested from the drive using SDO transfers.
Beginning with Operating Systems 1.28 (9030/9040) and 2.28 (9630/9640) with the compatible 1.03.08 EPL version, ACR controllers expand support of EPL drive communication and configuration via SDO transfers.
An EPL drive stores current process and device data in the Object Dictionary (OD), including communication parameters, device identification, and specific functionalities of a device. The Object Dictionary is based on CANopen and follows the same format. The OD contains both standardized objects common to all devices and manufacturer specific objects. Each object within the dictionary is addressed using a 16-bit index and an 8-bit sub-index.
ACR ETHERNET Powerlink controllers utilize both Service Data Object (SDO) transfer and Process Data Object (PDO) transfer as methods of exchanging data with other devices. The ACR controller reads and writes data to and from drives using SDO (during network start and set-up) and PDO (periodically during normal operation) without direct interaction by the user or user programs. The ACR9000 manipulates these objects as required automatically, as the underlying method of normal network operation.
SDO Example
