Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Training - Interact Xpress with Parker-SSD AC890 Drive Products
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
The following two files provide an example of how to configure a Parker-EMN Interact Express HMI project and a Parker-SSD AC890 Drive product to achieve communications and allow for data transfer.
Note - The HMI products do not have any formal SSD product driver support at this time.  The attached examples make use of a more generic Modbus Ethernet driver.  For any specific settings questions, please contact the Parker-SSD division about the Modbus Ethernet implementation in the AC890 drives and the Interact Xpress Manager driver help file for Modbus Ethernet.
AC890 to Xpress via Modbus Ethernet
Parker-SSD Product Support:  704-602-6062     (email:  techsupport.us.ssd@parker.com)    (Internet:  http://www.parker.com/ssdusa )
Thanks to our distributor Olympus Controls for this contribution.
glh  Feb-2013
