Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Misc - Compax3 EtherCAT Delta robot (Video)
Below video shows a Delta robot with 3 servo motors being controlled via Compax3 I31 EtherCAT.
