Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base General - EME (Europe) Parker SMB SME SMH MB ME MH motors
These motors can be purchased in North America through your local Parker Automation Technology Center distributor through our custom product process. Please provide the full part number on the side of the motor and serial number, or if possible a clear picture of the motor's nameplate. The custom products group will confirm the motor is standard or custom to make sure the provided replacement is identical.
For customers willing and able to switch the servo amplifier and cables, our newer MPP/MPJ series servo motors offer higher performance in a smaller package and a full range of standard feedback options. Please contact your local Parker ATC for a servo motor crossover.
Full specifications (latest versions of manuals and catalogs) are available on Parker.com. Just type SME in search and select Low-Inertia Brushless Servo Motors:
For questions on these motors, email Parker Electromechanical Europe at:  em-motion@parker.com
For reference only:
SMB SME catalog
SMH MH catalog
MB ME catalog
2/21/13jh
 3/15/19dom
keywords:
CP*SMBA1003-14738 SMBA1003
CP*SMBA1004W-15073 SMBA6060148110VK
CP*SMBA142-14833 SMB11530
CP*SMBA60601-14253
CP*SMBA60601-14742
CP*SMB1003-13553
CP*SMB10030-14422
CP*SMB10030-14712
CP*SMB10030-15153
CP*SMB100300-14578
CP*SMB100300-14743
CP*SMB100300-14840
CP*SMB115-14227
CP*SMB11530-14834
CP*SMB115301-13724
CP*SMB40500-14174
CP*SMB60301-13790
CP*SMB60301-14621
CP*SMB60301-14748
CP*SMB60301-15131
CP*SMB60451W-15072
CP*SMB60601-14484
CP*SMB60601-15151
CP*SMB82-15139 SMB8216038
CP*SMB82300-14912 SMB8230035192D64
CP*SMB82300-15152 SMBA1003006
CP*SMB823003-13898 SMBA100450
CP*SMB823003-14263
CP*SMB823003-14328
CP*SMB82303-14749
CP*SMB824-13577
CP*SMB82450-15071
CP*SMB82800-14762
SMBA10030065192ID6
SMBA10045065192IZW
SMBA1423015519S2I6 CP*SMBA142-14833
SMBA60601 SMBA6060148110
SMBA6060148110VK64
SMB1003006519S3M64 SMB100300
SMB10030065192B654
SMB10030065192IBW6
SMB10030065192ID65
SMB10030065193MB64 SMB10030065
SMB1153010524S2I64 CP*SMB11530-14834
SMB11530108A13MB64
SMB1153010819S2B64
SMB405003589S2YC64 CP*SMB40500-14174
SMB6030145113M642 CP*SMB60301-15131
SMB6030148112ID65 CP*SMB60301-13790
SMB603014892ID64V2 SMB60301
SMB603014892ID65
SMB604514892IZW652 SMB60451
SMB606014811S3M642 SMB606014811S3
SMB8216038193MB642 SMB8216038
SMB823003519S3M64
SMB8230035192D64V2
SMB8230035192ID652 SMB82300
SMB8230038142ID65
SMB8230038143M64-230
SMB82400381421D64
SMB8245038142IZW65 SMB8245038
SMB8280035A60K644
SME60601
CP*SMHA60105-13984
CP*SMHA60601-14028 SMHA60601
CP*SMHA60601-14782
CP*SMHA60601-15123
CP*SMHA82600-14783
CP*SMHA8275-14131
CP*SMH10056-14896
CP*SMH10056-15205
CP*SMH115301-14413
CP*SMH40-60-13983
CP*SMH60-105-13985
CP*SMH6030-14147
CP*SMH60601-14412
CP*SMH826003-14451
SMHA601051489S2ID CP*SMHA60105-13984
SMHA606014511S2ID6 SMHA60601
SMHA6060145112ID CP*14028
SMHA606014892ID654 CP*14782
SMHA8260038142ID65 SMHA826003
SMHA8275038142ID65
SMH10056065192ID65 SMH1005606519
SMH10056065193M654
SMH115301-7192ID65
SMH4060035560V64 SMH40-60-0,CP*13983
SMH601051489S2ID
SMH6030145112ID65
SMH6060145112ID65 SMH60601
SMH8260038-14451 SMH8260038
CP*MBV145300-13717
CP*MB10520-14187
CP*MB10530-14336 MB1053004519S3164
CP*MB10530-14392 MB1053002519S164
CP*MB105300-14665 MB1053004519164
CP*MB105300-14987 MB10530065194B644
CP*MB105300-15021 MB1053006519164
CP*MB1053002519164
CP*MB1053006-12632
CP*MB1053008-13944
CP*MB10560-14229
CP*MB105600-14790 MB1056004519164
CP*MB14530-14566
CP*MB14556-14770
CP*MB14560-14260
CP*MB14560-14990 MB14560085241642
CP*MB56250-14323
CP*MB56250-14735 MB5625045V220
CP*MB70370-14391 MB703702514S0864
CP*MB70702-14791 MB7070255144B644
CP*SMBA1003-14738
CP*SMBA1004W-15073
CP*SMBA142-14833
CP*SMBA60601-14253
CP*SMBA60601-14742 SMBA6060148110VK
CP*SMB1003-13553
CP*SMB10030-14422
CP*SMB10030-14712
MBA1053006519164 CP*MBA10530-13948
MBA1053006519164V4
MBA145-30-22-5-24
MBA1453022528164
MBA14530225283MB64 CP*14888
MBA1453028528S2I64 CP*15025
MBSV10530025191364 CP*MBSV10530-13803
MBSV1453022524164
MBSV1454515524164
MBSV20520705423644 MBSV205207
MBSV2053070503833 MBSV205307
MBSV20530705383364 CP*MBSV205-14960
MBV14510155243365 CP*MBV145-14171
MBV14530085243164 CP*MBV145300-13717
MB1052008524164400
MB1053002519S164V4 MB1053002519S164V4
MB1053002519164 CP*MB1053002519164
MB1053004519S3164 MB1053004519S3164
MB1053004519164V23 MB1053004519164V230
MB10530065191644 MB10530065
MB10530065194B644 MB10530065
MB1053008519S3C64
MB1053008519164M220 MB1053008519164MV220
MB1056004519164V4 MB105600451916V400
MB10560045194B64 CP*MB10560-14229
MB1453022524164V400
MB1453022528164
MB14556085241364M4
MB1456008524S3364
MB14560085241642 MB14560085
MB5625045908642V2 MB5625045
MB562506590864-220 MB562506
MB703702514S0864V4 MB703702514S0864
MB7070255144B644V4 MB7070255144B644
SMBA10030065192ID6
SMBA10045065192IZW SMBA100450
SMBA60601
SMBA6060148110VK64 SMBA6060148110
SMB1003006519S3M64
SMB10030065192B654
SMB10030065192IBW6 SMB1003006
SMB10030065192ID65 SMB100300
SMB11530108A13MB64 CP*SMB115301-13724
SMB1153010819S2B64 CP*SMB115-14227
SMB603014892ID64V2
SMB603014892ID65
SMB823003519S3M64 SMB82300
SMB8230035192D64V2
SMB8230035192ID652
SMB8230038142ID65
SMB82400381421D64
SMB8245038142IZW65
SMB8280035A60K644
SME6060145112ND64B
SMB60301
SMH100
SMB60301
SMB823003
SMB8245038
SMB1003006
SMB100300
SMB60301
SMB823
SMBA1004
SMB606
SMB823003
SMH100
SMBA1004
SMB6030145
SMB60451W
SMB10030
SMB100300
SMBA14230
SMB823003
SMB8245038
CP*SMB824-13577
SMB8280035A60K
SME60601
SMH11530
CP*SMH60-105-13985
CP*SMB824-13577
SMB100300
SMB8230
CP*SMB115301-13724
CP*SMB115-14227
SMHA826003
SMHA60601
MB1053008519164M220
MB14530
SMB606
SMH11530
