Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How can the 890 family be configured?
  • AC/DC Industrial Drives-
    • AC890 Series-
    • AC15/AC20+
    • DESAT (OVER I) Fault
Like many of the other AC products, there are several ways to configure the 890SD, 890CD, 890SD, or 890PX.
  1. The 890 can be configured using DSELite software - One at a time via the USB connection on the front of the drive.
  2. An entire 890 System can be configured using DSE890 software - Multiple at once within one project environment.
  3. The 890 can be configured using the keypad, but is normally reserved for error tracking and general monitoring.
    1. Programming capability is limited using the keypad - You will not be able to set everything nor introduce more robust logic into the system.
    2. It is extremely difficult programming using the 6511 keypad simply due to the small display. Should be reserved just for error handling and simple monitoring.
    3. It is difficult programming using the 6901 keypad, again due to the limitations of the display.
7NOV2016 LS
Updated JD 14MAY19
  • configure
  • 890
