Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What is the current overload rating for the AC890 drive?
    • AC890 Series-
  1. Frames B - D AC890 have an overload rating of 150% for 60 seconds.
  2. AC890 Frame sizes E and above have an overload rating of 150% for 60 seconds in Constant Torque and 110% for 60 seconds in Quadratic Torque.
  3. The AC890PX has an overload rating of 150% for 60 seconds in Constant Torque and 110% for 60 seconds in Quadratic Torque.
7NOV2016 LS
  • rating
  • Current
  • overload
