Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How can the AC890 be reset to factory defaults?
  • AC/DC Industrial Drives-
    • AC890 Series-
    • AC15/AC20+
    • DESAT (OVER I) Fault
Method 1:
  1. Power down the drive entirely.
  2. Hold the Up and Down arrow buttons.
  3. Power up the drive.
    1. Keypad should read "RESTORE DEFAULTS, UP TO CONFIRM".
  4. Press UP.
    1. Keypad should read "RESTORE DEFAULTS, COMPLETE".
Method 2:
  1. The second method is to simply install a default template from the DSELite or DSE890 software.
This information is also found in the product manuals:
7NOV2016 LS
  • reset
  • default
  • factory
  • 890
