Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gearhead Specs - RT Gearheads - Torque to tighten Taperlock bushing
  • Gearheads-
For the Stealth MultiDrive RT series gearheads, the through-hole is tightened with a taper lock bushing.
For the RT115 the bolts are to be torqued to 6 ft-lbs, the RT142 and RT180 sizes are 9 ft-lbs of torque.
For RT90, consult factory.
