Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Is the keypad detachable during operation?
    • AC890 Series-
  1. Only if the drive is being controlled through the remote terminal connections.
  2. If the keypad is connected with the drive powered up, a COMS CODE fault may occur.
  3. Cycle power to reset the fault.
7NOV2016 LS
  • keypad
  • 890
