Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What are the minimum and maximum 3-phase input voltage ratings on an 890SD, CD, CS and PX?
    • AC890 Series-
This information can also be found in the manuals:
  1. The AC890CS voltage rating is 208-500VAC (±10%).
  2. The AC890CD voltage rating.
    1. ---/2/--- 230VNOMINAL is 320 VDC
    2. ---/5/--- (400VAC) is 560Vdc
    3. ---/5/--- (460VAC) is 650-705VDC
  3. The AC890SD voltage rating.
    1. ---/2/--- 230Vac is 208-240VAC (±10%)
    2. ---/4/--- 400/460Vac is 380-460VAC (±10%) therefore 506Vac MAXIMUM before an Overvoltage occurs
    3. ---/5/--- 400/500Vac is 380-460VAC (±10%) therefore 506Vac MAXIMUM before an Overvoltage occurs
  4. The AC890PX voltage rating.
    1. ---/4/--- 400/460VNOMINAL is 380-460VAC (±10%)
    2. ---/6/--- 600VNOMINAL is 500-575VAC (±10%)
    3. ---/7/--- 690VNOMINAL is 600-690VAC (±10%)
7NOV2016 LS
Update 25Feb20 jd
  • minimum
  • maximum
  • 890
  • 3phase
