Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What safety standards does the 890 meet?
  • AC/DC Industrial Drives-
    • AC890 Series-
      • AH469910U001 - Use 8904/A/US/03/00 to order replacements
    • AC15/AC20+
    • DESAT (OVER I) Fault
  1. The AC890:
    1. Meets the UL and c-UL standards:
      • Type 1, Suitable for cubical mount only
      • Must be installed to EN60204 Standards.
      • Must meet requirements of UL50.
  2. The AC890PX:
    1. Meets the UL, and c-UL standards:
      • As defined by UL50, Suitable for cubical mount only.
    2. Meets the CE standards:
      • Meets the requirements of IP21.
      • As defined by EN60529.
This information is taken straight out of the manuals, that can be found on the respective product pages:
IMAGE BROKEN -- DCLIFFEIMAGE BROKEN -- DCLIFFE
8NOV2016 LS
  • EC
  • 890PX
  • standards
  • CE
  • UL
  • 890
