Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Kit Motors - Frameless Kit Motor windings
The new Bayside catalog pages for the frameless kit motors show common motors used for 120 and 240vac applications for quick delivery.
If your application is using a low-voltage or needing specific speed-torques, we do have 9 frame sizes of kit motors available from .25-in to 3.00-in stack lengths with 13 different windings that can be in wye or delta.
All the windings are shown on our website here:
Frameless Kit Motor Windings
For a specific speed and torque with a given voltage, you may contact the factory via email at pumptechsupport@parker.com
An applications engineer can help in selecting the motor and provide speed-torques curves, current-speed curves, efficiency-speed curves along with the full electrical specifications. Please specify the continuous torque, peak torque, speed and voltage available on the machine.
