Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Dynaserv G3 Drive Drawings
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
Drawing and solid models for Dynaserv G3 Servo Drives.
500W 2KW
DXF G3_500_dxf G3_2KW_dxf
STP G3_500_STP G3_2KW_STP
IGS G3_500_IGS G3_2KW_IGS
ModelNumber 2KW 500W
DMG3-1xxxxA X
DMG3-1xxxxB* X
DMG3-1004B X
DRG3-1xxxC X
DRG3-1xxxA X
DRG3-1xxxB X
DRG3-1xxxE X
DRG3-5xxxB X
DRG3-5xxxE X
DRG3-5xxxC X
*Excluding DMG3-1004B
jw mar-2013
