Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Software - Firmware and C3ServoManager Archive
Below chart shows the compatibility of the Compax3 controller board revision (CTP) and firmware (.fwp):
To determine the Compax3 controller board version
1. Connect serial cable to x10 port
2.  Power on 24vdc (AC power not necessary) on x4
3. Using the latest version of C3 ServoManager software (which is backwards compatible with previous firmware versions) and under Device Selection  >   Online device identification (double-click on left, or single-click at right on  'Click to Begin "Hardware auto-detect" '
When the C3 ServoManager uploads, it'll show what the hardware is, what it is software configured as and the Controller board version (CTP) and the existing firmware release number:
To download firmware to the Compax3, using C3 ServoManager, under Download (PC -> Compax3), select Compax3 firmware package (double-click) or single-click 'Click to Begin "Compax3 firmware download" ' and follow instructions:
 Current version of C3 ServoManager:  http://solutions.parker.com/c3_support
Archive for previous versions of C3ServoManager, PIET, Codesys, C3 Codesys Targets:
Note to download: Right-click and select "Save Target As..."
For .fwp files, Microsoft Internet Explorer doesn't recognize this extension and will default as .zip. Change the pulldown to All File Types and change the .zip back to .fwp:
2015R9-70
C3_Servo_Manager_Setup_R09-70.exe
C3 2016R09-74_041220.fwp
2014R9-68
C3_Servo_Manager_Setup_R09-68.exe
C3_2014R09-65_041114.fwp
2014R9-62
c3_2014R09-62_041112.fwp
C3 Servo Manager Setup R09-62.exe
Compax3 Codesys Targets r09-62.zip
CoDeSys Installation 2.3.9.26.exe
C3MultiAxis_USB.zip
User Manuals & Online Help Files: R9-62_Documentation.zip
2013R9-61
Setup_C3MGR2_R09-61.exe
2013R9-50
Setup_C3MGR2_R09-50.exe
2012R9-40
Setup_C3MGR2_R09-40.exe
2008R7
c3_2008r07-3.fwp
C3 Servo Manager Setup R07-3.exe
Parker Integrated Engineering Tool (PIET) for C3M multi-axis 1.0.0.19.exe
Compax3 Codesys Targets r07-03.zip
CoDeSys Installation 2.3.6.4.exe
2007R5
Firmware c3_2007r05-5.fwp
C3 Servo Manager Setup R05-3.exe
Compax3 Codesys Targets r05-3.zip
2006R4
Firmware C3_2007R04-15.fwp
C3 Servo Manager Setup R04-8.exe
Compax3 Codesy Targets R04-8.zip
CoDeSys Installation 2.3.5.5.exe
2005R3
Firmware C3_2004R03-3.fwp
C3 Servo Manager Setup R03-2.exe
Compax3 Codesys Targets 2004R3-2.zip
Codesys Installation 2.3.3.6.exe
2004R2
Firmware C3_2004R02-17.fwp
C3 Servo Manager Setup R02-15.exe
Compax3 Codesys Targets 2004R2-9.zip
CoDeSysV2.3_Setup.zip
Other firmwares:
C3_2003R02-1.fwp
C3_2004R02-9.fwp
C3_2004R02-17.fwp
C3_2004R02-23.fwp
C3_2004R03-3.fwp
C3_2005R04-1.fwp
C3_2005R04-2.fwp
C3_2005R04-3.fwp
C3_2005R04-5.fwp
C3_2005R04-8.fwp
C3_2005R04-9.fwp
C3_2006R05-2.fwp
C3_2007R04-15.fwp
C3_2007R05-3.fwp
C3_2007R05-4.fwp
C3_2007R05-5.fwp
C3_2007R07-1.fwp
C3_2008R05-7.fwp
C3_2008R07-3.fwp
C3_2008R08-0.fwp
C3_2008R08-1.fwp
C3_2009R08-3.fwp
C3_2009R08-3_EPL.fwp
C3_2009R08-4.fwp
C3_2010R08-6.fwp
C3_2010R09-0.fwp
C3_2010R09-0_EPL_V202.fwp
C3_2010R09-1.fwp
C3_2010R09-2.fwp
C3_2010R09-10_EPLv205.fwp
C3_2011R09-11.fwp
C3_2011R09-20_040813.fwp
C3_2011R09-30_040906.fwp
C3_2012R09-32_040914.fwp
C3_2012R09-40_041016.fwp
C3_2013R09-41.fwp
C3_2013R09-42_041028.fwp
C3_2014R09-62_041112.fwp
C3_2014R09-64_041114.fwp
C3_2016R09-74_041220.fwp
C3_2016R09-75_041220.fwp
C3_2017R09-76_041228.fwp
C3_2017R09-78_041233.fwp
C3_2018R09-79_041260.fwp
C3_2018R09-80.fwp
C3_2019R09-81.fwp
For other firmwares, email parker.germany@parker.com
or for the US or Canada: emn.service@support.parker.com
3/14/14jh
updated 10/22/15jh
updated 6/4/18jh
updated 11/19/19jh
