Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base User Function Block: Read Actual Torque
      • 9000 (Legacy)+
      • IEC PLC (9600) (Legacy)-
        • PLCOpen State Machine
        • Using arrays in IEC PLC
AXIS_READTORQUE is a user function block that enables the user to monitor actual torque output of an axis. Download the code here : Axis_ReadTorque
The block reports the Final Ouput Signal parameter. Read here for full explanation. User can also input a ScaleFactor that is multiplied by the final output signal allowing the user to represent Torque or Force in units that are meaningful to the application.
VAR_IN_OUT
AXIS AXIS_REF Axis Reference
VAR_INPUT
ENABLE BOOL Enables the block to perform the read
ScaleFactor REAL Default = 1.0. This value is multipled by FINALOUTPUT to produce ActualTorque
VAR_OUTPUT
VALID BOOL Block is reading properly
FINALOUTPUT REAL Read here
ActualTorque REAL FinalOutput Signal x ScaleFactor
Error BOOL Signals that error has occurred within function block
ErrorID WORD Error identification
jw Mar-2013
