Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gearhead Misc - Stealth MultiDrive Direction output
  • Gearheads-
For the Stealth MultiDrive RB, RD and RT series gearheads, how do you determine for the dual output (RD) which face of the gearhead turns in which direction?
The side where the bevel gear is located has a flange with a set screw positioned toward the motor. This output face would rotate opposite from the gearbox input direction.
Gearbox assembly
Gear Detail
