Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Motors - Brake Option Specifications, Wiring Diagrams, Configuration Parameters (for P Series Drives)
P Series Motors are offered with optional static/holding brakes.
These are spring style brakes designed for holding a load during a power-off condition.
They are not intended to stop motion.
Brake Specifications
Motor Series PM-FAL PM-FBL PM-FCL PM-FE PM-FF
Frame Size 40mm 60mm 80mm 130mm 180mm
Input Power 24VDC 24VDC 24VDC 24VDC 24VDC
Static Friction Torque Nm 0.32 1.47 3.23 10.4 40
Rated Current Amps 0.25 0.27 0.38 0.81 1.04
Capacity W 6 6.5 9 19.4 40
Coil Resistance Ohms 96 89 64 29.6 23
Note - the brake option require a separate cable as leads are not included in the motor power cable.
Brake Cables
APCS-BN03QS Brake Cable, 3 meters
APCS-BNxxQS xx=Length in meters : 05, 10, 20
Wiring Diagrams
The P series servo drives do not include a brake relay for direct control of a motor's electromechanical brake.  Instead, an external relay is required, which can be controlled by the brake control signals (digital outputs).
P Drive Brake Circuit Wiring Diagram.pdf
Note - separate power supply is recommended for brake power versus to avoid electrical noise issues.
Wiring example shown with ACR9000/ACR7000 controllers.
For brake timing related parameters, see section 6.9 (PD-xxC) or section 6.10.2 (PD-xxP) in the applicable user guide for further details and timing diagrams.
PD-xxC (brake signal output function defaults to Digital Output1 - DO1)
0x2407 (brake output speed)
0x2408 (brake output delay time)
0x2011 (PWM off delay time)
Note - there is a typo in the rev A user guide in section 6.9 that mentions 0x200F, when it should actually be 0x2011.
PD-xxP (brake signal output function defaults to Digital Output1 - DO3)
Notes - To hold the load while the brake engages the motor shaft, use object 0x2011 PWM Off Delay time.  This should be set to the Brake Engage Time.  This is most common on vertical systems to prevent the load from dropping due to the time it takes for the brake circuit and brake to fully engage.
This will hold the motor current when the drive is disabled, giving delay for the brake to engage the motor shaft:
4/19/16jh added wiring
7/21/19 jw update diagram
9/20/19 jh added brake delay
glh Dec 2020 combined separate FAQ's into single one
