Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - EnDat 2.2 Compatible
As of release 9-40 firmware and C3 ServoManager version, the Compax3 with the F12 encoder feedback option supports EnDat 2.2 (digital, no commutation tracks).
Note - The Compax3 does not support the motor temperature information via the digital data however.  (updated 5/9/19)
Parker motors currently do not have this feedback as an option as standard but are available as custom.
Maximum cable length is 25m
6/28/13jh
5/9/19 glh
