Option Notes:
3.
0: Half stack motor was retired in 2007. A replacement for the SM160 and SM230 motors is the BE160 or BE230 motor family. Or move to the next stack length, the SM161 or SM231
5.
R: Resolver, only available for SM23x motors. Must order MS, PS or LC connector option.
J: 2000 line encoder will be available in early 2014.
Q: 2000 line smart encoder will retire in late 2013. Recommended replacement is "J"
D: 500 line-count encoder. Retired as standard option in 2007 but is available as a custom motor.
H: Hall-only feedback option. This option is not available as a custom. Alternatively order a standard encoder feedback motor (such as a J option), and use just the hall signal from the encoder as a hall-only solution.
6.
L: longer shaft length. Retired as standard option in 2007 but is available as a custom motor.
T: longer motor shaft, with a keyway on the motor shaft. Retired as standard option in 2007 but is available as a custom motor.
7.
25: 25ft cable . This was retired as standard option in 2007 but is available as a custom motor.
TQ: TQ style connectors. Retired as standard option in 2007.No longer available as a custom as of Dec 2012
8:
Gxx Integrated Gearhead option is no longer available. See here for replacement options.
F3 34frame flange, available on SM23. Available as custom.
nov 2013 jw, 1/6/16jh updated below pn list
SM161AE-F10N, SM161AE-FFLN, SM161AE-FGSN, SM161AE-FMSN, SM161AE-FPSN, SM161AE-N10N, SM161AE-NFLN, SM161AE-NGSN, SM161AE-NLCN, SM161AE-NMSN, SM161AE-NPSN, SM161AL-FMSN, SM161AL-FPSN, SM161AL-NMSN, SM161AL-NPSN, SM161AQ-FLCN, SM161AQ-FMSN, SM161AQ-FPSN, SM161AQ-NLCN, SM161AQ-NMSN, SM161AQ-NPSN, SM161BE-F10N, SM161BE-FFLN, SM161BE-FLCN, SM161BE-FMSN, SM161BE-FPSN, SM161BE-N10N, SM161BE-NFLN, SM161BE-NLCN, SM161BE-NMSN, SM161BE-NPSN, SM161BL-FMSN, SM161BL-FPSN, SM161BL-NMSN, SM161BL-NPSN, SM161BQ-FLCN, SM161BQ-NLCN, SM161BQ-NPSN, SM162AE-F10N, SM162AE-FFLN, SM162AE-FGSN, SM162AE-FLCN, SM162AE-FMSN, SM162AE-FPSN, SM162AE-N10N, SM162AE-NFLN, SM162AE-NGSN, SM162AE-NLCN, SM162AE-NMSN, SM162AE-NPSN, SM162AL-FMSN, SM162AL-FPSN, SM162AL-NGSN, SM162AL-NMSN, SM162AL-NPSN, SM162AQ-FLCN, SM162AQ-FMSN, SM162AQ-FPSN, SM162AQ-NLCN, SM162AQ-NMSN, SM162AQ-NPSN, SM162BE-F10N, SM162BE-FFLN, SM162BE-FLCN, SM162BE-FMSN, SM162BE-FPSN, SM162BE-N10N, SM162BE-NFLN, SM162BE-NLCN, SM162BE-NMSN, SM162BE-NPSN, SM162BL-FMSN, SM162BL-FPSN, SM162BL-NMSN, SM162BL-NPSN, SM162BQ-FLCN, SM162BQ-NLCN, SM162BQ-NPSN, SM162ZE-FMSN, SM162ZE-FPSN, SM162ZE-NMSN, SM162ZE-NPSN, SM162ZL-FMSN, SM162ZL-FPSN, SM162ZL-NMSN, SM162ZL-NPSN, SM162ZQ-FLCN, SM162ZQ-FMSN, SM162ZQ-FPSN, SM162ZQ-NLCN, SM162ZQ-NMSN, SM162ZQ-NPSN, SM230AD-NMSN, SM230AE-F10N, SM230AE-FFLN, SM230AE-N10N, SM230AE-NFLN, SM230AE-NGSN, SM230AE-NMSN, SM230AE-NTQN, SM230BD-FMSN, SM230BD-NFLN, SM230BE-FFLN, SM230BE-N10N, SM230BE-NFLN, SM230BE-NMSN, SM230BE-NTQN, SM231AD-FGSN, SM231AD-FMSN, SM231AD-FTQN, SM231AD-KFLG10, SM231AD-KFLG55, SM231AD-KGSG55, SM231AD-KGSN, SM231AD-KMSV, SM231AD-N10N, SM231AD-N25N, SM231AD-NFLF3, SM231AD-NFLN, SM231AD-NFLV, SM231AD-NGSN, SM231AD-NMSN, SM231AD-NTQN, SM231AD-NTQV, SM231AD-TMSN, SM231AE-F10B, SM231AE-F10N, SM231AE-F10N, SM231AE-FFLB, SM231AE-FFLN, SM231AE-FFLN, SM231AE-FFON, SM231AE-FGSB, SM231AE-FGSBV, SM231AE-FGSN, SM231AE-FGSN, SM231AE-FLCB, SM231AE-FLCN, SM231AE-FMSB, SM231AE-FMSBV, SM231AE-FMSN, SM231AE-FMSN, SM231AE-FMSV, SM231AE-FMSV, SM231AE-FPSB, SM231AE-FPSBV, SM231AE-FPSN, SM231AE-FPSV, SM231AE-FTQN, SM231AE-K10B, SM231AE-K10G10, SM231AE-K10G100, SM231AE-K10N, SM231AE-K10N, SM231AE-KFLB, SM231AE-KFLG10, SM231AE-KFLG55, SM231AE-KFLN, SM231AE-KFON, SM231AE-KGSB, SM231AE-KGSBV, SM231AE-KGSG03, SM231AE-KGSG05, SM231AE-KGSG07, SM231AE-KGSG10, SM231AE-KGSG100, SM231AE-KGSG22, SM231AE-KGSN, SM231AE-KGSN, SM231AE-KGSV, SM231AE-KLCB, SM231AE-KLCN, SM231AE-KMSB, SM231AE-KMSBV, SM231AE-KMSG22, SM231AE-KMSG55, SM231AE-KMSN, SM231AE-KMSN, SM231AE-KMSV, SM231AE-KPSB, SM231AE-KPSBV, SM231AE-KPSN, SM231AE-KPSV, SM231AE-KTQG10, SM231AE-KTQG100, SM231AE-KTQG22, SM231AE-KTQN, SM231AE-KTQV, SM231AE-L10N, SM231AE-LFLN, SM231AE-LGSN, SM231AE-LMSN, SM231AE-LTQN, SM231AE-N10B, SM231AE-N10N, SM231AE-N10N, SM231AE-N25N, SM231AE-NFLB, SM231AE-NFLN, SM231AE-NFLN, SM231AE-NFON, SM231AE-NGSB, SM231AE-NGSBV, SM231AE-NGSN, SM231AE-NGSN, SM231AE-NGSV, SM231AE-NGSV, SM231AE-NLCB, SM231AE-NLCN, SM231AE-NMSB, SM231AE-NMSBV, SM231AE-NMSN, SM231AE-NMSN, SM231AE-NMSV, SM231AE-NMSV, SM231AE-NPSB, SM231AE-NPSBV, SM231AE-NPSN, SM231AE-NPSV, SM231AE-NTQN, SM231AE-NTQV, SM231AE-TGSN, SM231AE-TTQN, SM231AH-FFLN, SM231AH-N10N, SM231AH-NFLN, SM231AH-NMSN, SM231AL-FGSB, SM231AL-FGSBV, SM231AL-FMSB, SM231AL-FMSBV, SM231AL-FMSN, SM231AL-FMSV, SM231AL-FPSB, SM231AL-FPSBV, SM231AL-FPSN, SM231AL-FPSV, SM231AL-KGSB, SM231AL-KGSBV, SM231AL-KMSB, SM231AL-KMSBV, SM231AL-KMSN, SM231AL-KMSV, SM231AL-KPSB, SM231AL-KPSBV, SM231AL-KPSN, SM231AL-KPSV, SM231AL-NGSB, SM231AL-NGSBV, SM231AL-NGSN, SM231AL-NMSB, SM231AL-NMSBV, SM231AL-NMSN, SM231AL-NMSV, SM231AL-NPSB, SM231AL-NPSBV, SM231AL-NPSN, SM231AL-NPSV, SM231AQ-FLCB, SM231AQ-FLCN, SM231AQ-FMSB, SM231AQ-FMSBV, SM231AQ-FMSN, SM231AQ-FMSV, SM231AQ-FPSB, SM231AQ-FPSBV, SM231AQ-FPSN, SM231AQ-FPSV, SM231AQ-KLCB, SM231AQ-KLCN, SM231AQ-KMSB, SM231AQ-KMSBV, SM231AQ-KMSN, SM231AQ-KMSV, SM231AQ-KPSB, SM231AQ-KPSBV, SM231AQ-KPSN, SM231AQ-KPSV, SM231AQ-NLCB, SM231AQ-NLCN, SM231AQ-NMSB, SM231AQ-NMSBV, SM231AQ-NMSN, SM231AQ-NMSV, SM231AQ-NPSB, SM231AQ-NPSBV, SM231AQ-NPSN, SM231AQ-NPSN, SM231AQ-NPSV, SM231AR-FLCB, SM231AR-FLCN, SM231AR-FMSB, SM231AR-FMSBV, SM231AR-FMSN, SM231AR-FMSN, SM231AR-FMSV, SM231AR-FMSV, SM231AR-FPSB, SM231AR-FPSBV, SM231AR-FPSN, SM231AR-FPSV, SM231AR-KLCB, SM231AR-KLCN, SM231AR-KMSB, SM231AR-KMSBV, SM231AR-KMSG10, SM231AR-KMSG100, SM231AR-KMSN, SM231AR-KMSN, SM231AR-KMSV, SM231AR-KPSB, SM231AR-KPSBV, SM231AR-KPSN, SM231AR-KPSV, SM231AR-LMSN, SM231AR-NLCB, SM231AR-NLCN, SM231AR-NMSB, SM231AR-NMSBV, SM231AR-NMSF3, SM231AR-NMSN, SM231AR-NMSN, SM231AR-NMSV, SM231AR-NMSV, SM231AR-NPSB, SM231AR-NPSBV, SM231AR-NPSN, SM231AR-NPSV, SM231BD-FMSN, SM231BD-KFLG10, SM231BD-KTQG10, SM231BD-N10F3, SM231BD-N10N, SM231BD-NFLN, SM231BD-NMSN, SM231BD-NMSV, SM231BD-NTQN, SM231BE-F10B, SM231BE-F10N, SM231BE-F10N, SM231BE-FFLB, SM231BE-FFLN, SM231BE-FFLN, SM231BE-FFON, SM231BE-FLCB, SM231BE-FLCN, SM231BE-FMSB, SM231BE-FMSBV, SM231BE-FMSN, SM231BE-FMSN, SM231BE-FMSV, SM231BE-FPSB, SM231BE-FPSBV, SM231BE-FPSN, SM231BE-FPSV, SM231BE-K10B, SM231BE-K10N, SM231BE-K10N, SM231BE-KFLB, SM231BE-KFLG100, SM231BE-KFLG55, SM231BE-KFLN, SM231BE-KFON, SM231BE-KLCB, SM231BE-KLCN, SM231BE-KMSB, SM231BE-KMSBV, SM231BE-KMSG03, SM231BE-KMSN, SM231BE-KMSV, SM231BE-KPSB, SM231BE-KPSBV, SM231BE-KPSN, SM231BE-KPSV, SM231BE-KTQG10, SM231BE-KTQN, SM231BE-L10N, SM231BE-LFLN, SM231BE-N10B, SM231BE-N10N, SM231BE-N10N, SM231BE-N25N, SM231BE-NFLB, SM231BE-NFLN, SM231BE-NFLN, SM231BE-NFON, SM231BE-NGSN, SM231BE-NLCB, SM231BE-NLCN, SM231BE-NMSB, SM231BE-NMSBV, SM231BE-NMSN, SM231BE-NMSN, SM231BE-NMSV, SM231BE-NMSV, SM231BE-NPSB, SM231BE-NPSBV, SM231BE-NPSN, SM231BE-NPSV, SM231BE-NTQN, SM231BE-TMSN, SM231BH-N10N, SM231BL-FMSB, SM231BL-FMSBV, SM231BL-FMSN, SM231BL-FMSV, SM231BL-FPSB, SM231BL-FPSBV, SM231BL-FPSN, SM231BL-FPSV, SM231BL-KMSB, SM231BL-KMSBV, SM231BL-KMSN, SM231BL-KMSV, SM231BL-KPSB, SM231BL-KPSBV, SM231BL-KPSN, SM231BL-KPSV, SM231BL-NMSB, SM231BL-NMSBV, SM231BL-NMSN, SM231BL-NMSV, SM231BL-NPSB, SM231BL-NPSBV, SM231BL-NPSN, SM231BL-NPSV, SM231BR-FLCB, SM231BR-FLCN, SM231BR-FMSB, SM231BR-FMSBV, SM231BR-FMSN, SM231BR-FMSV, SM231BR-FPSB, SM231BR-FPSBV, SM231BR-FPSN, SM231BR-FPSV, SM231BR-KLCB, SM231BR-KLCN, SM231BR-KMSB, SM231BR-KMSBV, SM231BR-KMSN, SM231BR-KMSV, SM231BR-KPSB, SM231BR-KPSBV, SM231BR-KPSN, SM231BR-KPSV, SM231BR-NLCB, SM231BR-NLCN, SM231BR-NMSB, SM231BR-NMSBV, SM231BR-NMSN, SM231BR-NMSN, SM231BR-NPSB, SM231BR-NPSBV, SM231BR-NPSN, SM231BR-NPSV, SM232AD-FMSN, SM232AD-FTQN, SM232AD-K10N, SM232AD-KGSG03, SM232AD-N10N, SM232AD-NFLN, SM232AD-NGSN, SM232AD-NMSF3, SM232AD-NMSN, SM232AD-NTQN, SM232AD-T10N, SM232AE-F10B, SM232AE-F10N, SM232AE-F10N, SM232AE-FFLB, SM232AE-FFLN, SM232AE-FFLN, SM232AE-FFON, SM232AE-FGSB, SM232AE-FGSBV, SM232AE-FGSN, SM232AE-FGSN, SM232AE-FLCB, SM232AE-FLCN, SM232AE-FMSB, SM232AE-FMSBV, SM232AE-FMSN, SM232AE-FMSN, SM232AE-FMSV, SM232AE-FPSB, SM232AE-FPSBV, SM232AE-FPSN, SM232AE-FPSV, SM232AE-FTQN, SM232AE-K10B, SM232AE-K10G05, SM232AE-K10G10, SM232AE-K10G22, SM232AE-K10N, SM232AE-K10N, SM232AE-K10V, SM232AE-K25G05, SM232AE-KFLB, SM232AE-KFLG22, SM232AE-KFLN, SM232AE-KFLN, SM232AE-KFON, SM232AE-KGSB, SM232AE-KGSBV, SM232AE-KGSG03, SM232AE-KGSG07, SM232AE-KGSG10, SM232AE-KGSG22, SM232AE-KGSG55, SM232AE-KGSN, SM232AE-KGSN, SM232AE-KGSV, SM232AE-KGSV, SM232AE-KLCB, SM232AE-KLCN, SM232AE-KMSB, SM232AE-KMSBV, SM232AE-KMSG03, SM232AE-KMSG10, SM232AE-KMSG22, SM232AE-KMSG55, SM232AE-KMSN, SM232AE-KMSN, SM232AE-KMSV, SM232AE-KMSV, SM232AE-KPSB, SM232AE-KPSBV, SM232AE-KPSN, SM232AE-KPSV, SM232AE-KTQG07, SM232AE-KTQG10, SM232AE-KTQN, SM232AE-L10N, SM232AE-LFLN, SM232AE-LGSN, SM232AE-LGSV, SM232AE-LTQF3, SM232AE-LTQN, SM232AE-N10B, SM232AE-N10F3, SM232AE-N10N, SM232AE-N10N, SM232AE-N10V, SM232AE-N25N, SM232AE-NFLB, SM232AE-NFLF3, SM232AE-NFLN, SM232AE-NFLN, SM232AE-NFON, SM232AE-NGSB, SM232AE-NGSBV, SM232AE-NGSN, SM232AE-NGSN, SM232AE-NGSV, SM232AE-NGSV, SM232AE-NLCB, SM232AE-NLCN, SM232AE-NMSB, SM232AE-NMSBV, SM232AE-NMSN, SM232AE-NMSN, SM232AE-NMSV, SM232AE-NMSV, SM232AE-NPSB, SM232AE-NPSBV, SM232AE-NPSN, SM232AE-NPSV, SM232AE-NTQF3, SM232AE-NTQN, SM232AE-NTQV, SM232AE-T10N, SM232AE-TGSN, SM232AH-FMSN, SM232AH-K10G10, SM232AH-N10N, SM232AH-NFLN, SM232AH-NMSN, SM232AH-NMSV, SM232AL-FGSB, SM232AL-FGSBV, SM232AL-FMSB, SM232AL-FMSBV, SM232AL-FMSN, SM232AL-FMSV, SM232AL-FPSB, SM232AL-FPSBV, SM232AL-FPSN, SM232AL-FPSV, SM232AL-KGSB, SM232AL-KGSBV, SM232AL-KMSB, SM232AL-KMSBV, SM232AL-KMSN, SM232AL-KMSV, SM232AL-KPSB, SM232AL-KPSBV, SM232AL-KPSN, SM232AL-KPSV, SM232AL-NGSB, SM232AL-NGSBV, SM232AL-NGSN, SM232AL-NMSB, SM232AL-NMSBV, SM232AL-NMSN, SM232AL-NMSV, SM232AL-NPSB, SM232AL-NPSBV, SM232AL-NPSN, SM232AL-NPSV, SM232AQ-FLCB, SM232AQ-FLCN, SM232AQ-FMSB, SM232AQ-FMSBV, SM232AQ-FMSN, SM232AQ-FMSV, SM232AQ-FPSB, SM232AQ-FPSBV, SM232AQ-FPSN, SM232AQ-FPSV, SM232AQ-KLCB, SM232AQ-KLCN, SM232AQ-KMSB, SM232AQ-KMSBV, SM232AQ-KMSN, SM232AQ-KMSV, SM232AQ-KPSB, SM232AQ-KPSBV, SM232AQ-KPSN, SM232AQ-KPSV, SM232AQ-NLCB, SM232AQ-NLCN, SM232AQ-NMSB, SM232AQ-NMSBV, SM232AQ-NMSN, SM232AQ-NMSV, SM232AQ-NPSB, SM232AQ-NPSBV, SM232AQ-NPSN, SM232AQ-NPSN, SM232AQ-NPSV, SM232AR-FLCB, SM232AR-FLCN, SM232AR-FMSB, SM232AR-FMSBV, SM232AR-FMSN, SM232AR-FMSN, SM232AR-FMSV, SM232AR-FPSB, SM232AR-FPSBV, SM232AR-FPSN, SM232AR-FPSV, SM232AR-KLCB, SM232AR-KLCN, SM232AR-KMSB, SM232AR-KMSBV, SM232AR-KMSG05, SM232AR-KMSG5, SM232AR-KMSG55, SM232AR-KMSN, SM232AR-KMSN, SM232AR-KMSV, SM232AR-KPSB, SM232AR-KPSBV, SM232AR-KPSN, SM232AR-KPSV, SM232AR-LMSN, SM232AR-NLCB, SM232AR-NLCN, SM232AR-NMSB, SM232AR-NMSBV, SM232AR-NMSF3, SM232AR-NMSN, SM232AR-NMSN, SM232AR-NMSV, SM232AR-NPSB, SM232AR-NPSBV, SM232AR-NPSN, SM232AR-NPSV, SM232AR-TMSN, SM232BD-FMSN, SM232BD-K10N, SM232BD-L10V, SM232BD-LMSN, SM232BD-N10N, SM232BD-N25V, SM232BD-NFLN, SM232BD-NTQN, SM232BE-F10B, SM232BE-F10N, SM232BE-F10N, SM232BE-FFLB, SM232BE-FFLN, SM232BE-FFLN, SM232BE-FFON, SM232BE-FLCB, SM232BE-FLCN, SM232BE-FMSB, SM232BE-FMSBV, SM232BE-FMSN, SM232BE-FMSN, SM232BE-FMSV, SM232BE-FPSB, SM232BE-FPSBV, SM232BE-FPSN, SM232BE-FPSV, SM232BE-FTQN, SM232BE-K10B, SM232BE-K10G05, SM232BE-K10G10, SM232BE-K10N, SM232BE-K10N, SM232BE-KFLB, SM232BE-KFLG05, SM232BE-KFLN, SM232BE-KFLN, SM232BE-KFON, SM232BE-KGSG10, SM232BE-KLCB, SM232BE-KLCN, SM232BE-KMSB, SM232BE-KMSBV, SM232BE-KMSG03, SM232BE-KMSG05, SM232BE-KMSN, SM232BE-KMSN, SM232BE-KMSV, SM232BE-KPSB, SM232BE-KPSBV, SM232BE-KPSN, SM232BE-KPSV, SM232BE-KTQG10, SM232BE-KTQN, SM232BE-L10N, SM232BE-LMSN, SM232BE-N10B, SM232BE-N10N, SM232BE-N10N, SM232BE-N25N, SM232BE-NFLB, SM232BE-NFLN, SM232BE-NFLN, SM232BE-NFON, SM232BE-NGSN, SM232BE-NLCB, SM232BE-NLCN, SM232BE-NMSB, SM232BE-NMSBV, SM232BE-NMSN, SM232BE-NMSN, SM232BE-NMSV, SM232BE-NMSV, SM232BE-NPSB, SM232BE-NPSBV, SM232BE-NPSN, SM232BE-NPSV, SM232BE-NTQN, SM232BE-TTQN, SM232BH-N10N, SM232BH-NFLN, SM232BH-NMSN, SM232BL-FMSB, SM232BL-FMSBV, SM232BL-FMSN, SM232BL-FMSV, SM232BL-FPSB, SM232BL-FPSBV, SM232BL-FPSN, SM232BL-FPSV, SM232BL-KMSB, SM232BL-KMSBV, SM232BL-KMSN, SM232BL-KMSV, SM232BL-KPSB, SM232BL-KPSBV, SM232BL-KPSN, SM232BL-KPSV, SM232BL-NGSB, SM232BL-NGSN, SM232BL-NMSB, SM232BL-NMSBV, SM232BL-NMSN, SM232BL-NMSV, SM232BL-NPSB, SM232BL-NPSBV, SM232BL-NPSN, SM232BL-NPSV, SM232BR-FLCB, SM232BR-FLCN, SM232BR-FMSB, SM232BR-FMSBV, SM232BR-FPSB, SM232BR-FPSBV, SM232BR-FPSN, SM232BR-FPSV, SM232BR-KLCB, SM232BR-KLCN, SM232BR-KMSB, SM232BR-KMSBV, SM232BR-KMSG10, SM232BR-KMSN, SM232BR-KMSN, SM232BR-KPSB, SM232BR-KPSBV, SM232BR-KPSN, SM232BR-KPSV, SM232BR-NLCB, SM232BR-NLCN, SM232BR-NMSB, SM232BR-NMSBV, SM232BR-NMSN, SM232BR-NMSN, SM232BR-NPSB, SM232BR-NPSBV, SM232BR-NPSN, SM232BR-NPSV, SM233AD-F10N, SM233AD-KFLG03, SM233AD-KMSN, SM233AD-N10N, SM233AD-NFLN, SM233AD-NGSN, SM233AD-NMSV, SM233AD-NTQN, SM233AE-F10B, SM233AE-F10N, SM233AE-FFLB, SM233AE-FFLN, SM233AE-FFLN, SM233AE-FFON, SM233AE-FGSB, SM233AE-FGSBV, SM233AE-FGSN, SM233AE-FGSN, SM233AE-FGSV, SM233AE-FGSV, SM233AE-FLCB, SM233AE-FLCN, SM233AE-FMSB, SM233AE-FMSBV, SM233AE-FMSN, SM233AE-FMSN, SM233AE-FMSV, SM233AE-FMSV, SM233AE-FPSB, SM233AE-FPSBV, SM233AE-FPSN, SM233AE-FPSV, SM233AE-FTQN, SM233AE-K10B, SM233AE-K10G10, SM233AE-K10G22, SM233AE-K10N, SM233AE-K10N, SM233AE-KFLB, SM233AE-KFLN, SM233AE-KFON, SM233AE-KGSB, SM233AE-KGSBV, SM233AE-KGSG03, SM233AE-KGSG05, SM233AE-KGSG05-ETM, SM233AE-KGSG07, SM233AE-KGSG10, SM233AE-KGSG22, SM233AE-KGSG55, SM233AE-KGSN, SM233AE-KGSN, SM233AE-KLCB, SM233AE-KLCN, SM233AE-KMSB, SM233AE-KMSBV, SM233AE-KMSG10, SM233AE-KMSG22, SM233AE-KMSG55, SM233AE-KMSN, SM233AE-KMSN, SM233AE-KMSV, SM233AE-KMSV, SM233AE-KPSB, SM233AE-KPSBV, SM233AE-KPSN, SM233AE-KPSV, SM233AE-KTQG05, SM233AE-KTQG10, SM233AE-KTQN, SM233AE-KTQV, SM233AE-LFLN, SM233AE-LGSF3, SM233AE-LGSN, SM233AE-LMSF3, SM233AE-LMSN, SM233AE-LMSV, SM233AE-LTQN, SM233AE-N10B, SM233AE-N10N, SM233AE-N10N, SM233AE-N25N, SM233AE-NFLB, SM233AE-NFLN, SM233AE-NFLN, SM233AE-NFLV, SM233AE-NFON, SM233AE-NGSB, SM233AE-NGSBV, SM233AE-NGSF3, SM233AE-NGSN, SM233AE-NGSN, SM233AE-NGSV, SM233AE-NGSV, SM233AE-NLCB, SM233AE-NLCN, SM233AE-NMSB, SM233AE-NMSBV, SM233AE-NMSN, SM233AE-NMSN, SM233AE-NMSV, SM233AE-NPSB, SM233AE-NPSBV, SM233AE-NPSN, SM233AE-NPSV, SM233AE-NTQN, SM233AE-NTQV, SM233AE-TFLN, SM233AE-TGSN, SM233AE-TGSV, SM233AE-TMSN, SM233AE-TPSV, SM233AE-TTQN, SM233AH-FFLN, SM233AH-KFLN, SM233AH-N10N, SM233AH-NMSN, SM233AL-FGSB, SM233AL-FGSBV, SM233AL-FMSB, SM233AL-FMSBV, SM233AL-FMSN, SM233AL-FMSV, SM233AL-FPSB, SM233AL-FPSBV, SM233AL-FPSN, SM233AL-FPSV, SM233AL-KGSB, SM233AL-KGSBV, SM233AL-KMSB, SM233AL-KMSBV, SM233AL-KMSN, SM233AL-KMSV, SM233AL-KPSB, SM233AL-KPSBV, SM233AL-KPSN, SM233AL-KPSV, SM233AL-NGSB, SM233AL-NGSBV, SM233AL-NMSB, SM233AL-NMSBV, SM233AL-NMSN, SM233AL-NMSV, SM233AL-NPSB, SM233AL-NPSBV, SM233AL-NPSN, SM233AL-NPSV, SM233AQ-FLCB, SM233AQ-FLCN, SM233AQ-FMSB, SM233AQ-FMSBV, SM233AQ-FMSN, SM233AQ-FMSV, SM233AQ-FPSB, SM233AQ-FPSBV, SM233AQ-FPSN, SM233AQ-FPSV, SM233AQ-KLCB, SM233AQ-KLCN, SM233AQ-KMSB, SM233AQ-KMSBV, SM233AQ-KMSN, SM233AQ-KMSV, SM233AQ-KPSB, SM233AQ-KPSBV, SM233AQ-KPSN, SM233AQ-KPSV, SM233AQ-NLCB, SM233AQ-NLCN, SM233AQ-NMSB, SM233AQ-NMSBV, SM233AQ-NMSN, SM233AQ-NMSV, SM233AQ-NPSB, SM233AQ-NPSBV, SM233AQ-NPSN, SM233AQ-NPSN, SM233AQ-NPSV, SM233AR-FLCB, SM233AR-FLCN, SM233AR-FMSB, SM233AR-FMSBV, SM233AR-FMSN, SM233AR-FMSN, SM233AR-FMSV, SM233AR-FPSB, SM233AR-FPSBV, SM233AR-FPSN, SM233AR-FPSV, SM233AR-KLCB, SM233AR-KLCN, SM233AR-KMSB, SM233AR-KMSBV, SM233AR-KMSG07, SM233AR-KMSG22, SM233AR-KMSN, SM233AR-KMSN, SM233AR-KMSV, SM233AR-KMSV, SM233AR-KPSB, SM233AR-KPSBV, SM233AR-KPSN, SM233AR-KPSV, SM233AR-LMSN, SM233AR-NLCB, SM233AR-NLCN, SM233AR-NMSB, SM233AR-NMSBV, SM233AR-NMSN, SM233AR-NMSN, SM233AR-NMSV, SM233AR-NPSB, SM233AR-NPSBV, SM233AR-NPSN, SM233AR-NPSV, SM233AR-TMSN, SM233BD-F10N, SM233BD-FMSN, SM233BD-K10N, SM233BD-KTQG10, SM233BD-KTQV, SM233BD-LTQF3, SM233BD-LTQN, SM233BD-N10N, SM233BD-NFLN, SM233BD-NMSN, SM233BD-NMSV, SM233BD-NTQN, SM233BD-TFLN, SM233BE-F10B, SM233BE-F10N, SM233BE-F10N, SM233BE-F10V, SM233BE-F25N, SM233BE-F25V, SM233BE-FFLB, SM233BE-FFLN, SM233BE-FFLN, SM233BE-FFON, SM233BE-FLCB, SM233BE-FLCN, SM233BE-FMSB, SM233BE-FMSBV, SM233BE-FMSN, SM233BE-FMSN, SM233BE-FMSV, SM233BE-FMSV, SM233BE-FPSB, SM233BE-FPSBV, SM233BE-FPSN, SM233BE-FPSV, SM233BE-FTQN, SM233BE-K10B, SM233BE-K10G03, SM233BE-K10G22, SM233BE-K10N, SM233BE-K10N, SM233BE-K10V, SM233BE-K25G03, SM233BE-K25N, SM233BE-KFLB, SM233BE-KFLG03, SM233BE-KFLG10, SM233BE-KFLN, SM233BE-KFLN, SM233BE-KFON, SM233BE-KLCB, SM233BE-KLCN, SM233BE-KMSB, SM233BE-KMSBV, SM233BE-KMSG05, SM233BE-KMSG07, SM233BE-KMSG10, SM233BE-KMSG22, SM233BE-KMSN, SM233BE-KMSN, SM233BE-KMSV, SM233BE-KMSV, SM233BE-KPSB, SM233BE-KPSBV, SM233BE-KPSN, SM233BE-KPSV, SM233BE-KTQG05, SM233BE-KTQG10, SM233BE-KTQN, SM233BE-KTQVG22, SM233BE-L10N, SM233BE-LFLF3, SM233BE-LFLN, SM233BE-LTQF3, SM233BE-LTQN, SM233BE-N10B, SM233BE-N10N, SM233BE-N10N, SM233BE-N10V, SM233BE-N25N, SM233BE-NFLB, SM233BE-NFLF3, SM233BE-NFLN, SM233BE-NFLN, SM233BE-NFON, SM233BE-NGSN, SM233BE-NLCN, SM233BE-NMSB, SM233BE-NMSBV, SM233BE-NMSN, SM233BE-NMSN, SM233BE-NMSV, SM233BE-NMSV, SM233BE-NPSB, SM233BE-NPSBV, SM233BE-NPSN, SM233BE-NPSV, SM233BE-NTQF3, SM233BE-NTQN, SM233BE-NTQV, SM233BE-T10N, SM233BE-TFLN, SM233BE-TMSN, SM233BE-TTQN, SM233BH-FMSN, SM233BH-N10N, SM233BH-NFLN, SM233BL-FMSB, SM233BL-FMSBV, SM233BL-FMSN, SM233BL-FMSV, SM233BL-FPSB, SM233BL-FPSBV, SM233BL-FPSN, SM233BL-FPSV, SM233BL-KMSB, SM233BL-KMSBV, SM233BL-KMSN, SM233BL-KMSV, SM233BL-KPSB, SM233BL-KPSBV, SM233BL-KPSN, SM233BL-KPSV, SM233BL-NMSB, SM233BL-NMSBV, SM233BL-NMSN, SM233BL-NMSV, SM233BL-NPSB, SM233BL-NPSBV, SM233BL-NPSN, SM233BL-NPSV, SM233BQ-FLCB, SM233BQ-FLCN, SM233BQ-FMSB, SM233BQ-FMSBV, SM233BQ-FMSN, SM233BQ-FMSV, SM233BQ-FPSB, SM233BQ-FPSBV, SM233BQ-FPSN, SM233BQ-FPSV, SM233BQ-KLCB, SM233BQ-KLCN, SM233BQ-KMSB, SM233BQ-KMSBV, SM233BQ-KMSN, SM233BQ-KMSV, SM233BQ-KPSB, SM233BQ-KPSBV, SM233BQ-KPSN, SM233BQ-KPSV, SM233BQ-NLCB, SM233BQ-NLCN, SM233BQ-NMSB, SM233BQ-NMSBV, SM233BQ-NMSN, SM233BQ-NMSV, SM233BQ-NPSB, SM233BQ-NPSBV, SM233BQ-NPSN, SM233BQ-NPSV, SM233BR-FLCB, SM233BR-FLCN, SM233BR-FMSB, SM233BR-FMSBV, SM233BR-FMSN, SM233BR-FMSN, SM233BR-FMSV, SM233BR-FMSV, SM233BR-FPSB, SM233BR-FPSBV, SM233BR-FPSN, SM233BR-FPSV, SM233BR-KFLN, SM233BR-KLCB, SM233BR-KLCN, SM233BR-KMSB, SM233BR-KMSBV, SM233BR-KMSG05, SM233BR-KMSG10, SM233BR-KMSG22, SM233BR-KMSG55, SM233BR-KMSN, SM233BR-KMSN, SM233BR-KMSV, SM233BR-KPSB, SM233BR-KPSBV, SM233BR-KPSN, SM233BR-KPSV, SM233BR-LMSF3, SM233BR-LMSN, SM233BR-NLCB, SM233BR-NLCN, SM233BR-NMSB, SM233BR-NMSBV, SM233BR-NMSF3, SM233BR-NMSF3V, SM233BR-NMSN, SM233BR-NMSN, SM233BR-NMSV, SM233BR-NMSV, SM233BR-NPSB, SM233BR-NPSBV, SM233BR-NPSN, SM233BR-NPSV, SM233BR-TMSN, SM233BR-TMSV, SM230AD-NFLN
