Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How to connect my device to Interact? Interact Cable Dictionary
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
Here is a pdf print of the Interact Cable Dictionary:
Interact_Cable_Dictionary.pdf
This same information is from the cbldict.HLP from Interact that's available at www.ctcusa.com -- that requires .HLP patch for Windows7 from Microsoft.
12/6/13jh
