Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables - Replacements for Discontinued Cable Sets
Old "PS" Cable (Set) Part Number New "PS" Motor Power Cable Part Number New "PS" Motor Feedback Cable Part Number
SM-PECB-xx P-1A1-xx F-1A1-xx
BE-PECB-xx P-3B1-xx F-1A1-xx
BE-CRCB-xx P-3B1-xx F-2B1-xx
BE-CECB-xx P-3B1-xx F-2C1-xx
70-PECB-xx P-1A1-xx F-1A1-xx
70-CRCB-xx P-1A1-xx F-2B1-xx
70-CECB-xx P-1A1-xx F-2C1-xx
92-PECB-xx P-3B1-xx F-1A1-xx
92-CRCB-xx P-3B1-xx F-2B1-xx
92-CECB-xx P-3B1-xx F-2C1-xx
71-021626-xx P-1A1-xx --
71-021627-xx P-3B1-xx --
71-021628-xx -- F-1A1-xx
71-021629-xx -- F-2B1-xx
71-022231-xx -- F-2C1-xx
71-022341-xx P-4B1-xx --
71-023383-xx P-4B2-xx --
71-023384-xx P-6B2-xx --
71-023381-xx -- F-3D1-xx
71-023382-xx -- F-3C1-xx
Related FAQ:  Servo Cable Selection & Drawings and Motor Pinouts
Discontinued KIT Part Number Description POWER Cable Part Number FEEDBACK Cable Part Number
105CX CABLE-10 CABLE KIT,105,COMPAX-SBC,10FT 71-020792-10 71-020668-10
105CX CABLE-25 CABLE KIT,105,COMPAX-SBC,25 FT 71-020792-25 71-020668-25
105GR CABLE-10 CABLE KIT,105GR,GEM RES,10 FT 71-020105-10 71-020621-10
105GR CABLE-25 CABLE KIT,105GR,GEM RES,25 FT 71-020105-25 71-020621-25
105GS CABLE-10 CABLE KIT,105GS,GEM ENC,10 FT 71-020105-10 71-020117-10
105GS CABLE-25 CABLE KIT,105GS,GEM ENC,25 FT 71-020105-25 71-020117-25
105RL CABLE-10 CABLE KIT,105,RES,FLY,10 FT 71-020919-10 71-020645-10
105RL CABLE-25 CABLE KIT,105,RES,FLY,25 FT 71-020919-25 71-020645-25
145CX CABLE-10 CABLE KIT,145,COMPAX-SBC,10 FT 71-020793-10 71-020668-10
145CX CABLE-25 CABLE KIT,145,COMPAX-SBC,25 FT 71-020793-25 71-020668-25
145GR CABLE-10 CABLE KIT,145GR,GEM RES,10 FT 71-020114-10 71-020621-10
145GR CABLE-25 CABLE KIT,145GR,GEM RES,25 FT 71-020114-25 71-020621-25
145GR CABLE-50 CABLE SET MOTOR/RESOLVER M145N 71-020114-50 71-020621-50
145GS CABLE-10 CABLE KIT,145GS,GEM ENC,10 FT 71-020114-10 71-020117-10
145GS CABLE-25 CABLE KIT,145GS,GEM ENC,25 FT 71-020114-25 71-020117-25
145RL CABLE-10 CABLE KIT,145,RES,FLY,10 FT 71-020920-10 71-020645-10
145RL CABLE-20 CABLE KIT,145,RES,FLY,20 FT 71-020920-20 71-020645-20
145RL CABLE-25 CABLE KIT,145,RES,FLY,25 FT 71-020920-25 71-020645-25
145RL CABLE-35 CABLE KIT,145,RES,FLY,35 FT 71-020920-35 71-020645-35
145RS CABLE-10 CABLE KIT,145,RES,FLY,MS,10 FT 71-020921-10 71-020645-10
145RS CABLE-25 CABLE KIT,145,RES,FLY,MS,25FT 71-020921-25 71-020645-25
145RS CABLE-45 CABLE KIT,145,RES,FLY,MS,45 FT 71-020921-45 71-020645-45
205CP CABLE-10 CABLE KIT,205,COMPAX-SBCPT,10F 71-020795-10 71-020669-10
205CP CABLE-25 CABLE KIT,205,COMPAX-SBCPT,25F 71-020795-25 71-020669-25
205CX CABLE-10 CABLE KIT,205,COMPAX-SBC,10 FT 71-020794-10 71-020668-10
205CX CABLE-25 CABLE KIT,205,COMPAX-SBC,25 FT 71-020794-25 71-020668-25
205GP CABLE-10 CABLE KIT,205GP,PT,RES GEM,10' 71-020622-10 71-020623-10
205GP CABLE-25 CABLE KIT,205GP,PT,GEM RES,25' 71-020622-25 71-020623-25
205GR CABLE-10 CABLE KIT,205GR,GEM RES,10 FT 71-020116-10 71-020621-10
205GR CABLE-25 CABLE KIT,205GR,GEM RES,25 FT 71-020116-25 71-020621-25
205GS CABLE-10 CABLE KIT,205GS,GEM ENC,10 FT 71-020116-10 71-020117-10
205GS CABLE-25 CABLE KIT,205GS,GEM ENC,25 FT 71-020116-25 71-020117-25
205RP CABLE-10 CABLE KIT,205,RES,FLY,PT,10FT 71-020923-10 71-020646-10
205RP CABLE-25 CABLE KIT,205,RES,FLY,PT,25 FT 71-020923-25 71-020646-25
205RS CABLE-10 CABLE KIT,205,RES,FLY,MS,10 FT 71-020922-10 71-020645-10
205RS CABLE-25 CABLE KIT,205,RES,FLY,MS,25 FT 71-020922-25 71-020645-25
23CX CABLE-10 CABLE KIT,23CX,COMPAX,10FT 71-018304-10 71-020104-10
23CX CABLE-25 CABLE KIT,23 CX,COMPAX,25 FT 71-018304-25 71-020104-25
23CX CABLE-35 CABLE KIT,23 CX,COMPAX,35 FT 71-018304-35 71-020104-35
23GB CABLE-05 CABLE KIT,23 GB,5 FT 71-018303-05 71-018309-05
23GB CABLE-10 CABLE KIT,23 GB,10 FT,W/BRK 71-018303-10 71-018309-10
23GB CABLE-15 CABLE KIT,23 GB,15 FT 71-018303-15 71-018309-15
23GB CABLE-20 CABLE KIT,23 GB,20 FT 71-018303-20 71-018309-20
23GB CABLE-25 CABLE KIT,23 GB,25 FT,W/BRK 71-018303-25 71-018309-25
23GB CABLE-30 CABLE KIT,23 GB,30 FT 71-018303-30 71-018309-30
23GB CABLE-35 CABLE KIT,23 GB,35 FT,W/BRK 71-018303-35 71-018309-35
23GB CABLE-40 CABLE KIT,23 GB,40 FT 71-018303-40 71-018309-40
23GB CABLE-45 CABLE KIT,23 GB,45 FT 71-018303-45 71-018309-45
23GB CABLE-50 CABLE KIT,23 GB,50 FT 71-018303-50 71-018309-50
23GR CABLE-05 CABLE KIT,23 RES,GEM,5 FT 71-018303-05 71-018307-05
23GR CABLE-10 CABLE KIT,23 RES,GEM,10 FT 71-018303-10 71-018307-10
23GR CABLE-15 CABLE KIT,23 RES,GEM,15 FT 71-018303-15 71-018307-15
23GR CABLE-20 CABLE KIT,23 RES,GEM,20 FT 71-018303-20 71-018307-20
23GR CABLE-25 CABLE KIT,23 RES,GEM,25 FT 71-018303-25 71-018307-25
23GR CABLE-30 CABLE KIT,23 RES,GEM,30 FT 71-018303-30 71-018307-30
23GR CABLE-35 CABLE KIT,23 RES,GEM,35 FT 71-018303-35 71-018307-35
23GR CABLE-40 CABLE KIT,23 RES,GEM,40 FT 71-018303-40 71-018307-40
23GR CABLE-45 CABLE KIT,23 RES,GEM,45 FT 71-018303-45 71-018307-45
23GR CABLE-50 CABLE KIT,23 RES,GEM,50 FT 71-018303-50 71-018307-50
23GS CABLE-05 CABLE KIT,23 GS,5 FT 71-018303-05 71-018308-05
23GS CABLE-10 CABLE KIT,GS 23,10 FT 71-018303-10 71-018308-10
23GS CABLE-15 CABLE KIT,23 GS,15 FT 71-018303-15 71-018308-15
23GS CABLE-20 CABLE KIT,23 GS,20 FT 71-018303-20 71-018308-20
23GS CABLE-25 CABLE KIT,23 GS,25 FT 71-018303-25 71-018308-25
23GS CABLE-30 CABLE KIT,23 GS,30 FT 71-018303-30 71-018308-30
23GS CABLE-35 CABLE KIT,23 GS,35 FT 71-018303-35 71-018308-35
23GS CABLE-40 CABLE KIT,23 GS,40 FT 71-018303-40 71-018308-40
23GS CABLE-45 CABLE KIT,23 GS,45 FT 71-018303-45 71-018308-45
23GS CABLE-50 CABLE KIT,23 GS,50 FT 71-018303-50 71-018308-50
23MS CABLE-10 CABLE KIT,MS,10 FT,SIZE 23 71-014675-10 71-015871-10
23MS CABLE-10-DEMO CABLE KIT,MS,10 FT,SIZE 23,DEM 71-014675-10 71-015871-10
23MS CABLE-25 CABLE KIT,MS,25 FT,SIZE 23 71-014675-25 71-015871-25
23MS CABLE-35 CABLE KIT,MS,35 FT,SIZE 23 71-014675-35 71-015871-35
23RS CABLE-10 CABLE KIT,RESOLVER,10 FT 71-014675-10 71-015870-10
23RS CABLE-25 CABLE KIT,RESOLVER,25 FT 71-014675-25 71-015870-25
23RS CABLE-35 CABLE KIT,23 RS MOTOR,35 FT+A61 71-014675-35 71-015870-35
23RS CABLE-50 CABLE KIT,23 RS MOTOR,50 FT 71-014675-50 71-015870-50
23TQ CABLE-10 CABLE KIT,TQ/MS,10 FT 71-015017-10 71-015886-10
23TQ CABLE-25 CABLE KIT,TQ/MS,25 FT 71-015017-25 71-015886-25
23TQ CABLE-35 CABLE KIT,TQ/MS,35 FT 71-015017-35 71-015886-35
610GR CABLE-10 CABLE KIT,GEMINI,610 MTR,10 FT 71-018234-10 71-018311-10
610GR CABLE-25 CABLE KIT,GEMINI,610 MTR,25 FT 71-018234-25 71-018311-25
610GR CABLE-35 CABLE KIT,GEMINI,610 MTR,35 FT 71-018234-35 71-018311-35
615GR CABLE-10 CABLE KIT,GEMINI,615 MTR,10 FT 71-018234-10 71-018311-10
615GR CABLE-25 CABLE KIT,GEMINI,615 MTR,25 FT 71-018234-25 71-018311-25
615GR CABLE-35 CABLE KIT,GEMINI,615 MTR,35 FT 71-018234-35 71-018311-35
620GR CABLE-10 CABLE KIT,GEMINI,620 MTR,10 FT 71-018234-10 71-018311-10
620GR CABLE-25 CABLE KIT,GEMINI,620 MTR,25 FT 71-018234-25 71-018311-25
620GR CABLE-35 CABLE KIT,GEMINI,620 MTR,35 FT 71-018234-35 71-018311-35
630GR CABLE-10 CABLE KIT,GEMINI,630 MTR,10 FT 71-018234-10 71-018311-10
630GR CABLE-25 CABLE KIT,GEMINI,630 MTR,25 FT 71-018234-25 71-018311-25
630GR CABLE-35 CABLE KIT,GEMINI,630 MTR,35 FT 71-018234-35 71-018311-35
635GR CABLE-10 CABLE KIT,GEMINI,635 MTR,10 FT 71-018235-10 71-018311-10
635GR CABLE-25 CABLE KIT,GEMINI,635 MTR,25 FT 71-018235-25 71-018311-25
635GR CABLE-35 CABLE KIT,GEMINI,635 MTR,35 FT 71-018235-35 71-018311-35
640GR CABLE-10 CABLE KIT,GEMINI,640 MTR,10 FT 71-018235-10 71-018311-10
640GR CABLE-25 CABLE KIT,GEMINI,640 MTR,25 FT 71-018235-25 71-018311-25
640GR CABLE-35 CABLE KIT,GEMINI,640 MTR,35 FT 71-018235-35 71-018311-35
70CX CABLE-10 CABLE KIT,70 CX,COMPAX,10 FT 71-018304-10 71-020104-10
70CX CABLE-25 CABLE KIT,70 CX,COMPAX,25 FT 71-018304-25 71-020104-25
70CX CABLE-35 CABLE KIT,70 CX,COMPAX,35 FT 71-018304-35 71-020104-35
70GB CABLE-05 CABLE KIT,70 GB,5 FT 71-018304-05 71-018309-05
70GB CABLE-10 CABLE KIT,70 GB,10 FT,W/BRK 71-018304-10 71-018309-10
70GB CABLE-15 CABLE KIT,70 GB,15 FT 71-018304-15 71-018309-15
70GB CABLE-20 CABLE KIT,70 GB,20 FT 71-018304-20 71-018309-20
70GB CABLE-25 CABLE KIT,70 GB,25 FT,W/BRK 71-018304-25 71-018309-25
70GB CABLE-30 CABLE KIT,70 GB,30 FT 71-018304-30 71-018309-30
70GB CABLE-35 CABLE KIT,70 GB,35 FT,W/BRK 71-018304-35 71-018309-35
70GB CABLE-40 CABLE KIT,70 GB,40 FT 71-018304-40 71-018309-40
70GB CABLE-45 CABLE KIT,70 GB,45 FT 71-018304-45 71-018309-45
70GB CABLE-50 CABLE KIT,70 GB,50 FT 71-018304-50 71-018309-50
70GR CABLE-05 CABLE KIT,70 RES,GEM,5 FT 71-018304-05 71-018307-05
70GR CABLE-10 CABLE KIT,70 RES,GEM,10 FT 71-018304-10 71-018307-10
70GR CABLE-15 CABLE KIT,70 RES,GEM,15 FT 71-018304-15 71-018307-15
70GR CABLE-20 CABLE KIT,70 RES,GEM,20 FT 71-018304-20 71-018307-20
70GR CABLE-25 CABLE KIT,70 RES,GEM,25 FT 71-018304-25 71-018307-25
70GR CABLE-30 CABLE KIT,70 RES,GEM,30 FT 71-018304-30 71-018307-30
70GR CABLE-35 CABLE KIT,70 RES,GEM,35 FT 71-018304-35 71-018307-35
70GR CABLE-40 CABLE KIT,70 RES,GEM,40 FT 71-018304-40 71-018307-40
70GR CABLE-45 CABLE KIT,70 RES,GEM,45 FT 71-018304-45 71-018307-45
70GR CABLE-50 CABLE KIT,70 RES,GEM,50 FT 71-018304-50 71-018307-50
70GS CABLE-05 CABLE KIT,70 GS,5 FT 71-018304-05 71-018308-05
70GS CABLE-10 CABLE KIT,70 GS,10 FT 71-018304-10 71-018308-10
70GS CABLE-15 CABLE KIT,70 GS,15 FT 71-018304-15 71-018308-15
70GS CABLE-20 CABLE KIT,70 GS,20 FT 71-018304-20 71-018308-20
70GS CABLE-25 CABLE KIT,70 GS,25 FT 71-018304-25 71-018308-25
70GS CABLE-30 CABLE KIT,70 GS,30 FT 71-018304-30 71-018308-30
70GS CABLE-35 CABLE KIT,70 GS,35 FT 71-018304-35 71-018308-35
70GS CABLE-40 CABLE KIT,70 GS,40 FT 71-018304-40 71-018308-40
70GS CABLE-45 CABLE KIT,70 GS,45 FT 71-018304-45 71-018308-45
70GS CABLE-50 CABLE KIT,70 GS,50 FT 71-018304-50 71-018308-50
70MS CABLE-10 CABLE KIT,MS CONN,SIZE70,10 FT 71-015531-10 71-015871-10
70MS CABLE-25 CABLE KIT,MS CONN,SIZE70,25 FT 71-015531-25 71-015871-25
70MS CABLE-35 CABLE KIT,70 MS MOTOR,35 FT 71-015531-35 71-015871-35
70RS CABLE-10 CABLE KIT,RESOLVER,10 FT,70 71-015531-10 71-015870-10
70RS CABLE-25 CABLE KIT,RESOLVER,70 FR,25 FT 71-015531-25 71-015870-25
70RS CABLE-35 CABLE KIT,70 RS MOTOR,35 FT 71-015531-35 71-015870-35
70RS CABLE-50 CABLE KIT,70 RS MOTOR,50 FT 71-015531-50 71-015870-50
70TQ CABLE-10 CABLE KIT,TQ MOTOR,10 FOOT -- --
70TQ CABLE-25 CABLE KIT,TQ MOTOR,25 FOOT -- --
70TQ CABLE-35 CABLE KIT,TQ MOTOR,35 FT -- --
92CX CABLE-10 CABLE KIT,92 CX,COMPAX,10 FT 71-018305-10 71-020104-10
92CX CABLE-25 CABLE KIT,92 CX,COMPAX,25 FT 71-018305-25 71-020104-25
92CX CABLE-35 CABLE KIT,92 CX,COMPAX,35 FT 71-018305-35 71-020104-35
92GB CABLE-05 CABLE KIT,92 GB,5 FT 71-018305-05 71-018309-05
92GB CABLE-10 CABLE KIT,92 GB,10 FT,W/BRK 71-018305-10 71-018309-10
92GB CABLE-15 CABLE KIT,92 GB,15 FT 71-018305-15 71-018309-15
92GB CABLE-20 CABLE KIT,92 GB,20 FT 71-018305-20 71-018309-20
92GB CABLE-25 CABLE KIT,92 GB,25 FT,W/BRK 71-018305-25 71-018309-25
92GB CABLE-30 CABLE KIT,92 GB,30 FT 71-018305-30 71-018309-30
92GB CABLE-35 CABLE KIT,92 GB,35 FT,W/BRK 71-018305-35 71-018309-35
92GB CABLE-40 CABLE KIT,92 GB,40 FT 71-018305-40 71-018309-40
92GB CABLE-45 CABLE KIT,92 GB,45 FT 71-018305-45 71-018309-45
92GB CABLE-50 CABLE KIT,92 GB,50 FT 71-018305-50 71-018309-50
92GR CABLE-05 CABLE KIT,92 RES,GEM,5 FT 71-018305-05 71-018307-05
92GR CABLE-10 CABLE KIT,92 RES,GEM,10 FT 71-018305-10 71-018307-10
92GR CABLE-15 CABLE KIT,92 RES,GEM,15 FT 71-018305-15 71-018307-15
92GR CABLE-20 CABLE KIT,92 RES,GEM,20 FT 71-018305-20 71-018307-20
92GR CABLE-25 CABLE KIT,92 RES,GEM,25 FT 71-018305-25 71-018307-25
92GR CABLE-30 CABLE KIT,92 RES,GEM,30 FT 71-018305-30 71-018307-30
92GR CABLE-35 CABLE KIT,92 RES,GEM,35 FT 71-018305-35 71-018307-35
92GR CABLE-40 CABLE KIT,92 RES,GEM,40 FT 71-018305-40 71-018307-40
92GR CABLE-45 CABLE KIT,92 RES,GEM,45 FT 71-018305-45 71-018307-45
92GR CABLE-50 CABLE KIT,92 RES,GEM,50 FT 71-018305-50 71-018307-50
92GS CABLE-05 CABLE KIT,92 GS,5 FT 71-018305-05 71-018308-05
92GS CABLE-10 CABLE KIT,92 GS,10 FT 71-018305-10 71-018308-10
92GS CABLE-15 CABLE KIT,92 GS,15 FT 71-018305-15 71-018308-15
92GS CABLE-20 CABLE KIT,92 GS,20 FT 71-018305-20 71-018308-20
92GS CABLE-25 CABLE KIT,92 GS,25 FT 71-018305-25 71-018308-25
92GS CABLE-30 CABLE KIT,92 GS,30 FT 71-018305-30 71-018308-30
92GS CABLE-35 CABLE KIT,92 GS,35 FT 71-018305-35 71-018308-35
92GS CABLE-40 CABLE KIT,92 GS,40 FT 71-018305-40 71-018308-40
92GS CABLE-45 CABLE KIT,92 GS,45 FT 71-018305-45 71-018308-45
92GS CABLE-50 CABLE KIT,92 GS,50 FT 71-018305-50 71-018308-50
92MS CABLE-10 CABLE KIT,MS CONN,NM92,10 FT 71-015532-10 71-015871-10
92MS CABLE-25 CABLE KIT,MS CONN,NM92,25 FT 71-015532-25 71-015871-25
92MS CABLE-35 CABLE KIT,92 MS MOTOR,35 FT 71-015532-35 71-015871-35
92RS CABLE-10 CABLE KIT,RESOLVER,NM92,10 FT 71-015532-10 71-015870-10
92RS CABLE-25 CABLE KIT,RESOLVER,NM92,25 FT 71-015532-25 71-015870-25
92RS CABLE-35 CABLE KIT,92 RS MOTOR,35 FT 71-015532-35 71-015870-35
92RS CABLE-50 CABLE KIT,92 RS MOTOR,50 FT 71-015532-50 71-015870-50
BE-CX CABLE-10 BE CABLE KIT,CX,10' 71-018304-10 71-020104-10
BE-CX CABLE-25 BE CABLE KIT,CX,25' 71-018304-25 71-020104-25
BE-CX CABLE-35 BE CABLE KIT,CX,35' 71-018304-35 71-020104-35
BE-GB CABLE-05 CABLE KIT,BE SERIES,GB,5 FT 71-018304-05 71-018309-05
BE-GB CABLE-10 CABLE KIT,BE SERIES,GS BRK,10' 71-018304-10 71-018309-10
BE-GB CABLE-15 CABLE KIT,BE SERIES,GB,15 FT 71-018304-15 71-018309-15
BE-GB CABLE-20 CABLE KIT,BE SERIES,GB,20 FT 71-018304-20 71-018309-20
BE-GB CABLE-25 CABLE KIT,BE SERIES,GS BRK,25' 71-018304-25 71-018309-25
BE-GB CABLE-30 CABLE KIT,BE SERIES,GB,30 FT 71-018304-30 71-018309-30
BE-GB CABLE-35 CABLE KIT,BE SERIES,GS BRK,35' 71-018304-35 71-018309-35
BE-GB CABLE-40 CABLE KIT,BE SERIES,GB,40 FT 71-018304-40 71-018309-40
BE-GB CABLE-45 CABLE KIT,BE SERIES,GB,45 FT 71-018304-45 71-018309-45
BE-GB CABLE-50 CABLE KIT,BE SERIES,GB,50 FT 71-018304-50 71-018309-50
BE-GR CABLE-05 CABLE KIT,BE RES,GEM,5 FT 71-018304-05 71-018307-05
BE-GR CABLE-10 CABLE KIT,BE RES,GEM,10 FT 71-018304-10 71-018307-10
BE-GR CABLE-15 CABLE KIT,BE RES,GEM,15 FT 71-018304-15 71-018307-15
BE-GR CABLE-20 CABLE KIT,BE RES,GEM,20 FT 71-018304-20 71-018307-20
BE-GR CABLE-25 CABLE KIT,BE RES,GEM,25 FT 71-018304-25 71-018307-25
BE-GR CABLE-30 CABLE KIT,BE RES,GEM,30 FT 71-018304-30 71-018307-30
BE-GR CABLE-35 CABLE KIT,BE RES,GEM,35 FT 71-018304-35 71-018307-35
BE-GR CABLE-40 CABLE KIT,BE RES,GEM,40 FT 71-018304-40 71-018307-40
BE-GR CABLE-45 CABLE KIT,BE RES,GEM,45 FT 71-018304-45 71-018307-45
BE-GR CABLE-50 CABLE KIT,BE RES,GEM,50 FT 71-018304-50 71-018307-50
BE-GS CABLE-05 CABLE KIT,BE SERIES,GS,5 FT 71-018304-05 71-018308-05
BE-GS CABLE-10 CABLE KIT,BE SERIES,GS,10 FT 71-018304-10 71-018308-10
BE-GS CABLE-15 CABLE KIT,BE SERIES,GS,15 FT 71-018304-15 71-018308-15
BE-GS CABLE-20 CABLE KIT,BE SERIES,GS,20 FT 71-018304-20 71-018308-20
BE-GS CABLE-25 CABLE KIT,BE SERIES,GS,25 FT 71-018304-25 71-018308-25
BE-GS CABLE-30 CABLE KIT,BE SERIES,GS,30 FT 71-018304-30 71-018308-30
BE-GS CABLE-35 CABLE KIT,BE SERIES,GS,35 FT 71-018304-35 71-018308-35
BE-GS CABLE-40 CABLE KIT,BE SERIES,GS,40 FT 71-018304-40 71-018308-40
BE-GS CABLE-45 CABLE KIT,BE SERIES,GS,45 FT 71-018304-45 71-018308-45
BE-GS CABLE-50 CABLE KIT,BE SERIES,GS,50 FT 71-018304-50 71-018308-50
BE-MS CABLE-10 CABLE KIT,BE SERIES,MS,10 FT 71-015531-10 71-015871-10
BE-MS CABLE-25 CABLE KIT,BE SERIES,MS,25 FT 71-015531-25 71-015871-25
BE-MS CABLE-35 CABLE KIT,BE SERIES,MS,35 FT 71-015531-35 71-015871-35
BE-RS CABLE-10 CABLE KIT,BE SERIES,RES,10 FT 71-015531-10 71-015870-10
BE-RS CABLE-25 CABLE KIT,BE SERIES,RES,25 FT 71-015531-25 71-015870-25
BE-RS CABLE-35 CABLE KIT,BE SERIES,RES,35 FT 71-015531-35 71-015870-35
BE-RS CABLE-50 CABLE KIT,BE SERIES,RES,50 FT 71-015531-50 71-015870-50
BE-TQ CABLE-10 CABLE KIT,BE SERIES,TQ,10 FT -- --
BE-TQ CABLE-25 CABLE KIT,BE SERIES,TQ,25 FT -- --
BE-TQ CABLE-35 CABLE KIT,BE SERIES,TQ,35 FT -- --
