Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gem6K (GV6K & GT6K) Family Letter of Volatility
The attached is a Letter of Volatility for the GEM6K (GV6K & GT6K) Family of servo drive/controllers.
GEM6K LOV
Note - this letter is not applicable to the GV / GV6 or GT / GT6 products, only the full 6K versions.
glh April 2014   4/2014
  • letter of volatility
