Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Training - Express Basics Training: How to upload & download to 6K controllers (VIDEO)
Basic training on how to use MotionPlanner software to upload and download motion programs for Parker 6K controllers with serial RS232 communication.
Shows basic commands to query controller error report & axis status, and scaling.
Also shows the equipment required.
Note Motion Planner is compatible with Windows XP and Windows 7. It is not compatible with Windows vers 10 (Win10)
