Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Training - Express Basics Training: How to Connect Ethernet - includes Win7 (VIDEO)
How to enable ethernet (TCP/IP) communication for the 6K and Gem6K (GV6K/GT6K) products.
Shows some basic commands to query controller error report & axis status.  Also shows the equipment required.
Enabling 6K Ethernet from Motion Planner (.pdf)
For how to upload/download programs with MotionPlanner, see this FAQ: VIDEO: express basics training: 6K controllers
